Minimal permissions for a MS SQL record to connect to a database
Vasiliy Zverev
December 21, 2015
We are going to restrict permissions for a user which is used to connect to data date because of sequrity reasons. Is there any recomendations for this?
Dave C
December 21, 2015
Our https://confluence.atlassian.com/display/JIRA/Connecting+JIRA+to+SQL+Server+2012 docs indicate to setup a dedicated user for the JIRA database, and give them the db_owner permission to that database. This is required as JIRA will create tables, sequences and other information inside of the database when plugins are installed or upgraded.
rahuldanwade
December 21, 2015
As Atlassian recommends to create a dedicated user to access a jira database considering you have created separate database for JIRA.
you can a MySQL user called 'jirauser' and database called 'jiradb' and grant permissions to only jirauser to access 'jiradb'
please refer below documents.
https://confluence.atlassian.com/jira/setting-up-a-mysql-database-on-linux-for-jira-106004554.html
https://confluence.atlassian.com/jira/connecting-jira-to-mysql-185729489.html
I hope it would help!
thanks
Rahul
