The attachment section in the JIRA Issue View is missing. It is is same, like in this issue:
But my attachment field settings are correct:
If I click two times on issue key, the attachment section appears:
It seems, the attachment section is not appears in the issue filter view screen, but it appears on one issue view screen.
Are there anybody who experienced same behavior?
Hello @Tibor Gulyás ,
Check if you are using Security Fields and Attachments plugin:
it cause this behaviour, here is workaround:
Attachments do appear in the filter view in jira may be some issues internally
try post a bug report to atlassian that might help
