×When using JMWE's Set Issue Fields Post-Function, the dropdown list of fields is only showing 1 field (Affects versions) when, from our understanding, all fields should be listed here. In this particular instance, we are trying to set the Epic Link field, which is missing.
I've attached a screenshot here:
Hi @Paul Dhaliwal
Please connect with the JMWE support for the issue you are facing.
Customer Login - Help Center - Jira Service Management
Regarding Epic link field please observe the attached image below.
