After editing some fields and make other setting-changes there are no issuses displayed in my-issues-gadget an projects-gadget.
Have somebody an idea?
If you have added/changed some of your custom fields, have you performed a re-index since? Maybe something has gotten messed up in the index cache. I've had to completely delete the index cache before and re-index from scratch because it fell out of sync with the database making my filters not display properly and the standard reindex wouldn't fix it.
GREAT! It works! Tahnks
