Hi all,
I have asked alleged experts in my organization but no one is able to help me out with the construction of an AQL query that provides the following. Is this indeed an impossibiluty or are there solutions / workarounds that you could suggest?
Aching to hear from you as such a report would life so much easier!
Steve
Title |
Releases |
Assignee = currentUser() |
Sprint |
Target start date |
Target end date |
Due date |
Parent-Epic-Key |
Issue key |
Issue status |
Description |
Acceptance Criteria |
Uncommitted By |
Story Points (obviosuly only applicable to Story level) |
Hi. First Aql is for asset management. And the data field you listed are jira fields. So to help you with this filter i need to know what u are looking for because using current user means results are going to change based on the user id this looks like a scrum report....so what is goal of filter? If field not a criteria then content is displayed in filter by column visibility. Need more info to proceed
