Modify ProForma Question (Data Connection) returned value
Peter Ries September 13, 2023
we have set up a dropdown field in ProForma referring to a DataConnection getting data from an API.
we have data like this
   { id: 123, label: "abc"},
   { id 345, label: "def"}
where the label attributes are being displayed to the user.
How can we make proforma store/return the id as well in the answer. In processing backend we would need the id, not the user readable string.
Or as a workaround: can we somehow concatenate values from the API returned JSON to be displayed in the Label for the user.
Giedrius Daugmaudis September 15, 2023
The way I see it, 2 options:
  • Creating REST endpoint, that concentrates values and displays them in your desired format.
    Endpoint takes the data base link, then use endpoint link in the data connection. Screenshot 2023-09-15 104423.png
  • After submit, run answers endpoint and replace found values with automation/workflow script.
Option 2 likely more finicky.
