Monitor total project hours per calendar month - Support Agreements
ThePixel May 28, 2013
I am very new to Jira so would like to know how I can use it to track the number of hours spent on dev/support work per project each calendar month.
Some of our clients/projects pay for 20 hours dev/support work per calendar month, so I would like Jira to notify me when they projects getting close to using up all their hours for that month.
Thank you
ThePixel June 6, 2013
Sorted! Just needed to add Tempo!
Bhushan Nagaraj
May 29, 2013
Hi Kath,
Check this out
https://bitbucket.org/bhushan154/timereport/wiki/Home
It does not notify your users but it displays the total amount of time spent on each type of issue per week and per month.
Cheers
Bhushan
ThePixel May 29, 2013
Hi Bhushan
Thank you, that looks perfect! However I am using the onDemand version and I did not realise I can't use add-ons.
Timothy
May 29, 2013
Generally, what you will be using is JIRA's Time Tracking functionality.
https://confluence.atlassian.com/display/JIRA/Configuring+Time+Tracking
There are however alot of add-ons for JIRA which you can use to extend this functionalitity. You can find them at Atlassian's Marketplace.
