Move an issue to another project
Hanae alahcen
hello everybody
i have 5 issues that were created in the wrong place , i want to move each one to the appropriate project
is there a way to do it ?
Thanks a lot
Chung Park Chan
June 16, 2013
if you were to move each one to a different project, you need to do it one at a time. Refer to the link below on steps to do so:
https://confluence.atlassian.com/display/JIRA/Moving+an+Issue
Otherwise, you can choose Bulk Change.
Hope this helps, Hanae :)
Hanae alahcen
i guess that the move action was enough for me
thank you chung
and have a nice day :)
Hanae alahcen
I have to move 5 issues from differents project to the same project
the destination is the same but the source is not
Nic Brough -Adaptavist-
June 16, 2013
Chung Park Chan's answer is still valid.
Define a filter that includes those 5 issues. Use "bulk edit". It will offer you the option to move them (if it does not, then make sure you have "move" permission in the source projects and "create" in the target).
