Dear community,
My question is, can I move/Copy a project that is in Jira software and move or copy it in a sandbox environment?
Thank you
Hello @Francisco Navarro ,
This is build into the Jira administration portal. Here are the steps that you can take:
I have committed the steps in between, those are dependent on your environment en requirements but should be easy to figure out.
Good luck! Don't hesitate to ask further questions if you are stuck.
Thank you very much Paul,
But I see that this action will copy all the content from Jira software to my sandbox space?
Do you know of a method to copy only specific projects from jira software to my sandbox?
Sorry, I missed this comment. I don't think you can select which projects to copy. Of course, after copying the content, you can always delete the projects you don't need from your sandbox environment.
What would you like to achieve? What is it that you need the production data for? Perhaps you can re-create the situation from a blank slate?
n/a
Sorry about that @Francisco Navarro
If you wnat to export only one project, I think the only solution you might have is an add-on.
Take a look at https://marketplace.atlassian.com/apps/1211611/configuration-manager-for-jira-cmj?hosting=cloud&tab=overview
Forget my answer. The addon can help from server to cloud, but not sure if it can help from cloud to cloud
Salto.io can help copy the configuration of a single project from sandbox to production and vice versa. In general, we support a selective deployment of configuration elements between instances for both Jira Cloud and Jira Data Center.
