Move worklog, split worklog and delete worklog links missing from certain issues in Tempo
Catherine Steele
December 30, 2013
The move workflow, split worklog and delete worklog links are missing from some issues in tempo. I have checked the permission helper and the Time Tracking Permissions are showing that the affected user has 'Edit All Worklogs' permission
Susanne Götz [Tempo]
December 30, 2013
Hi Catherine,
this sounds like a bug that was reported to us in https://tempoplugin.jira.com/browse/TT-274. We are working on this and a fix will be released. As a workaround you will need to give the affected users the "delete own worklogs" or "delete all worklogs" permission.
Best regards
Susanne (Tempo)
Catherine Steele
December 30, 2013
The period is also open in the Tempo configuration settings
