Dear Community,
I ran into a problem to move an issue to a different project. It caused the problem with a MySQL permissions. Changed password to one without special characters. The problem with the DB seems have been solved but now I'm getting another exception:
com.atlassian.greenhopper.manager.lexorank.LexoRankIntegrityException: Expected exactly 2 rows; the maximum marker row and the lowest ranked row for rank field
Reindexing doesn't help. Any ideas ?
Best regards,
Arkady
Thanks a lot, Mikael.
Unfortunately the workaround didn't help. Every time when I add manually rows in AO_60DB71_LEXORANK for one rank id reported in the exception, then re-index JIRA, the next attempt to move the issue throws the same exception but with a new rank id. So I have to maually import once again the ranking rows for this id, etc....
More ideas?
Take a look at https://confluence.atlassian.com/jirakb/several-actions-such-as-issue-ranking-move-export-are-failing-779159169.html hopefully that will help you.
