I am playing around with Jira 5.06. I was moving some issues between projects, and I notice that the report becomes Anonymous. This happens whether I click on the retain value box or not.
It doesn't seem to be consistent though... I was able to get it to work earlier this morning.
Not sure what is going on -- anyone experience this before?
This normally happens when the old reporter doesn't have access in the new project. Can you check if the access rights is same in both the projects for that reporter?
*smacking head with hand* -- D'oh! That is exactly what is going on. Thanks for the quick reply! :)
that's my problem too. If you want to answer my recent question -- I will give you the answer!
