Multi project management WBS Gantt Chart
Andrea Fontanini
Hello!
I use WBS Gantt-Chart to manage company projects. In case I want to manage multiple projects at the same time, how do you suggest to proceed?
I was thinking of creating a specific gantt for each project (in order to work on each of them individually) and then creating a new gantt that includes all the projects that I want to manage simultaneously (see the picture below)
In this regard, however, I wanted to understand how to proceed if a new project is included at a later time which, in addition to managing it individually with a specific Gantt, I would like to manage jointly with the other projects already present in the portfolio. Any ideas or suggestions?
Another doubt I have in my procedure. If in the multi-project gantt you establish links and dependencies between tasks of different projects, will these be stored? And can these be updated if, as described above, you insert a new project and create a new multi-project gantt that includes it?
Thanks to those who will help me!
Edoardo Cavallini July 25, 2024
Hi, I do have the same request. Did you find a solution?
Thanks!
FREE
