×Hello,
I want create a multi projects board in Jira where all my issues from differents projects are show in one dedicated project, in this case call Hardware Scrum. All projects are Next-Gen. First I created my projects with a roadmap and some epics and loaded up with some issues. And then I created a a filter to get all the issues. I created a new board in the Hardware scrum projects base on the filter. Everythink look like it work, but, When I add some issues in the sprint and start the sprint, 0 issue are present in the sprint. You can see in the background that I added 2 issues to the sprint.. When I refresh, the sprint is empty.
Any Idea? Thank you for your help
HI André,
From the screenshot I can see that you have added the Next-Gen Issues to a classic Scrum board via the filter, and the two are not compatible. You will want to create a next-gen board to work with the next-gen project types.
This is covered in the note panel at the top of the "Working with next-gen software projects" documentation:
NOTE: To use a next-gen board, you need to create a next-gen Scrum or Kanban project. You cannot add a next-gen board to a classic Scrum or Kanban project.
Earl
