My Issues - Detail View - When changing status on an issue a blank screen returned
Annette Shoemaker
October 1, 2013
  1. Issues -> My Open Issues
  2. Views -> Detail View
  3. Click a button to progress an issue through the workflow (start work, close, etc)
Result: a message stating
"No issues were found to match your search
Try modifying your search criteria or creating a new issue"
Is returned instead of simply refreshing the existing search. If I execute the existing search, the correct results are returned, so I am not sure why this message even appears.
My development team is getting frustrated, is this a bug, is there a workaround?
Bharadwaj Jannu
October 2, 2013
Yes it is a bug. Stated in https://jira.atlassian.com/browse/JRA-34934
