Problem solved!
It was caused by my web browsers, clearing the web browser cache solved the problem.
Are that projects belonging the same category?
Have you change project logo by this steps:
Go to your project admin page:
[yourinstance].atlassian.net/plugins/servlet/project-config/[yourprojectkey]
Click "Edit Project"
Click "Project Avatar"
Pick another icon or choose from file
Yes, all the projects are from the same category "Software" projects.
Yes, I changed the project logos the way you described it.
