My jira is not starting. it is saying 'jira has problem in starting'
Sneha Agarwal
November 26, 2023
logs are as:
yDirectoryCleaner] Finished cleaning the temporary directory.
26-Nov-2023 17:59:15.885 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8090"]
26-Nov-2023 17:59:15.895 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in [3095] milliseconds
2023-11-26 17:59:16,020+0900 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger] Running Jira startup checks.
2023-11-26 17:59:16,020+0900 JIRA-Bootstrap FATAL [c.a.jira.startup.JiraStartupLogger] Startup check failed. Jira will be locked.
2023-11-26 17:59:16,058+0900 JIRA-Bootstrap INFO [c.a.jira.startup.LauncherContextListener] Startup is complete. Jira is ready to serve.
2023-11-26 17:59:16,059+0900 JIRA-Bootstrap INFO [c.a.jira.startup.LauncherContextListener] Memory Usage:
Heap memory : Used: 227 MiB. Committed: 384 MiB. Max: 2048 MiB
Non-heap memory : Used: 50 MiB. Committed: 104 MiB. Max: 1536 MiB
TOTAL : Used: 276 MiB. Committed: 488 MiB. Max: 3584 MiB
snehaagarwal@Snehas-MacBook-Air atlassian-jira-software-9.11.3 % clear
snehaagarwal@Snehas-MacBook-Air atlassian-jira-software-9.11.3 % cat /opt/atlassian-jira-software-9.11.3/logs/catalina.out
NOTE: Picked up JDK_JAVA_OPTIONS: --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.io=ALL-UNNAMED --add-opens=java.base/java.util=ALL-UNNAMED --add-opens=java.base/java.util.concurrent=ALL-UNNAMED --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED
26-Nov-2023 17:46:54.432 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version name: Apache Tomcat/9.0.82
26-Nov-2023 17:46:54.433 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Oct 11 2023 13:15:08 UTC
26-Nov-2023 17:46:54.433 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version number: 9.0.82.0
26-Nov-2023 17:46:54.433 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Mac OS X
26-Nov-2023 17:46:54.434 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 14.0
26-Nov-2023 17:46:54.434 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: aarch64
26-Nov-2023 17:46:54.434 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: /opt/homebrew/Cellar/openjdk/21.0.1/libexec/openjdk.jdk/Contents/Home
26-Nov-2023 17:46:54.434 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 21.0.1
26-Nov-2023 17:46:54.434 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Homebrew
26-Nov-2023 17:46:54.434 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: /opt/atlassian-jira-software-9.11.3
26-Nov-2023 17:46:54.434 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: /opt/atlassian-jira-software-9.11.3
26-Nov-2023 17:46:54.443 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.lang=ALL-UNNAMED
26-Nov-2023 17:46:54.444 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.io=ALL-UNNAMED
26-Nov-2023 17:46:54.444 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.util=ALL-UNNAMED
26-Nov-2023 17:46:54.444 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.util.concurrent=ALL-UNNAMED
26-Nov-2023 17:46:54.444 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED
26-Nov-2023 17:46:54.444 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=/opt/atlassian-jira-software-9.11.3/conf/logging.properties
26-Nov-2023 17:46:54.444 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
26-Nov-2023 17:46:54.444 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms384m
26-Nov-2023 17:46:54.444 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx2048m
26-Nov-2023 17:46:54.444 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:InitialCodeCacheSize=32m
26-Nov-2023 17:46:54.444 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:ReservedCodeCacheSize=512m
26-Nov-2023 17:46:54.444 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dlog4j2.contextSelector=org.apache.logging.log4j.core.selector.BasicContextSelector
26-Nov-2023 17:46:54.444 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dlog4j2.disableJmx=true
26-Nov-2023 17:46:54.444 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dlog4j2.garbagefree.threadContextMap=true
26-Nov-2023 17:46:54.444 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dlog4j2.isWebapp=false
26-Nov-2023 17:46:54.444 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.awt.headless=true
26-Nov-2023 17:46:54.444 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Datlassian.standalone=JIRA
26-Nov-2023 17:46:54.444 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true
26-Nov-2023 17:46:54.444 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dmail.mime.decodeparameters=true
26-Nov-2023 17:46:54.444 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.dom4j.factory=com.atlassian.core.xml.InterningDocumentFactory
26-Nov-2023 17:46:54.444 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:-OmitStackTraceInFastThrow
26-Nov-2023 17:46:54.444 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.locale.providers=COMPAT
26-Nov-2023 17:46:54.444 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Datlassian.plugins.startup.options=
26-Nov-2023 17:46:54.445 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djdk.tls.ephemeralDHKeySize=2048
26-Nov-2023 17:46:54.445 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.protocol.handler.pkgs=org.apache.catalina.webresources
26-Nov-2023 17:46:54.445 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.apache.catalina.security.SecurityListener.UMASK=0027
26-Nov-2023 17:46:54.445 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xlog:gc*:file=/opt/atlassian-jira-software-9.11.3/logs/atlassian-jira-gc-%t.log:tags,time,uptime,level:filecount=5,filesize=20M
26-Nov-2023 17:46:54.445 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+ExplicitGCInvokesConcurrent
26-Nov-2023 17:46:54.445 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dignore.endorsed.dirs=
26-Nov-2023 17:46:54.445 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=/opt/atlassian-jira-software-9.11.3
26-Nov-2023 17:46:54.445 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=/opt/atlassian-jira-software-9.11.3
26-Nov-2023 17:46:54.445 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=/opt/atlassian-jira-software-9.11.3/temp
26-Nov-2023 17:46:54.449 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The Apache Tomcat Native library which allows using OpenSSL was not found on the java.library.path: [/Users/snehaagarwal/Library/Java/Extensions:/Library/Java/Extensions:/Network/Library/Java/Extensions:/System/Library/Java/Extensions:/usr/lib/java:.]
26-Nov-2023 17:46:54.646 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
26-Nov-2023 17:46:54.652 INFO [main] org.apache.catalina.startup.Catalina.load Server initialization in [371] milliseconds
26-Nov-2023 17:46:54.660 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service [Catalina]
26-Nov-2023 17:46:54.660 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet engine: [Apache Tomcat/9.0.82]
2023-11-26 17:46:57,967+0900 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger]
Jira starting...
2023-11-26 17:46:58,001+0900 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger]
___ Environment _____________________________
JIRA Build : 9.11.3#9110003-sha1:68217899df0c52647a075db3f172daf1f7484786
Build Date : Thu Nov 09 00:00:00 KST 2023
JIRA Installation Type : Standalone
Application Server : Apache Tomcat/9.0.82 - Servlet API 4.0
Java Version : 21.0.1 - Homebrew
Current Working Directory : /opt/atlassian-jira-software-9.11.3
Maximum Allowable Memory : 2048MB
Total Memory : 384MB
Free Memory : 259MB
Used Memory : 125MB
Memory Pool: CodeHeap 'non-nmethods' : CodeHeap 'non-nmethods': init = 5849088(5712K) used = 1462912(1428K) committed = 5849088(5712K) max = 5849088(5712K)
Memory Pool: Metaspace : Metaspace: init = 0(0K) used = 25994344(25385K) committed = 26411008(25792K) max = -1(-1K)
Memory Pool: CodeHeap 'profiled nmethods' : CodeHeap 'profiled nmethods': init = 33554432(32768K) used = 11763584(11487K) committed = 33554432(32768K) max = 265502720(259280K)
Memory Pool: Compressed Class Space : Compressed Class Space: init = 0(0K) used = 2846928(2780K) committed = 3014656(2944K) max = 1073741824(1048576K)
Memory Pool: G1 Eden Space : G1 Eden Space: init = 24117248(23552K) used = 94371840(92160K) committed = 246415360(240640K) max = -1(-1K)
Memory Pool: G1 Old Gen : G1 Old Gen: init = 378535936(369664K) used = 31154608(30424K) committed = 148897792(145408K) max = 2147483648(2097152K)
Memory Pool: G1 Survivor Space : G1 Survivor Space: init = 0(0K) used = 6735056(6577K) committed = 7340032(7168K) max = -1(-1K)
Memory Pool: CodeHeap 'non-profiled nmethods' : CodeHeap 'non-profiled nmethods': init = 33554432(32768K) used = 2850944(2784K) committed = 33554432(32768K) max = 265519104(259296K)
JVM Input Arguments : --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.io=ALL-UNNAMED --add-opens=java.base/java.util=ALL-UNNAMED --add-opens=java.base/java.util.concurrent=ALL-UNNAMED --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED -Djava.util.logging.config.file=/opt/atlassian-jira-software-9.11.3/conf/logging.properties -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Xms384m -Xmx2048m -XX:InitialCodeCacheSize=32m -XX:ReservedCodeCacheSize=512m -Dlog4j2.contextSelector=org.apache.logging.log4j.core.selector.BasicContextSelector -Dlog4j2.disableJmx=true -Dlog4j2.garbagefree.threadContextMap=true -Dlog4j2.isWebapp=false -Djava.awt.headless=true -Datlassian.standalone=JIRA -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true -Dmail.mime.decodeparameters=true -Dorg.dom4j.factory=com.atlassian.core.xml.InterningDocumentFactory -XX:-OmitStackTraceInFastThrow -Djava.locale.providers=COMPAT -Datlassian.plugins.startup.options= -Djdk.tls.ephemeralDHKeySize=2048 -Djava.protocol.handler.pkgs=org.apache.catalina.webresources -Dorg.apache.catalina.security.SecurityListener.UMASK=0027 -Xlog:gc*:file=/opt/atlassian-jira-software-9.11.3/logs/atlassian-jira-gc-%t.log:tags,time,uptime,level:filecount=5,filesize=20M -XX:+ExplicitGCInvokesConcurrent -Dignore.endorsed.dirs= -Dcatalina.base=/opt/atlassian-jira-software-9.11.3 -Dcatalina.home=/opt/atlassian-jira-software-9.11.3 -Djava.io.tmpdir=/opt/atlassian-jira-software-9.11.3/temp
Java Compatibility Information : JIRA version = 9.11.3, Java Version = 21.0.1
___ Java System Properties _________________
apple.awt.application.name : Bootstrap
atlassian.plugins.startup.options :
atlassian.standalone : JIRA
catalina.base : /opt/atlassian-jira-software-9.11.3
catalina.home : /opt/atlassian-jira-software-9.11.3
catalina.useNaming : true
common.loader : "${catalina.base}/lib",
"${catalina.base}/lib/*.jar",
"${catalina.home}/lib",
"${catalina.home}/lib/*.jar"
file.encoding : UTF-8
ftp.nonProxyHosts : local|*.local|169.254/16|*.169.254/16
http.nonProxyHosts : local|*.local|169.254/16|*.169.254/16
ignore.endorsed.dirs :
java.awt.headless : true
java.class.version : 65.0
java.home : /opt/homebrew/Cellar/openjdk/21.0.1/libexec/openjdk.jdk/Contents/Home
java.io.tmpdir : /opt/atlassian-jira-software-9.11.3/temp
java.locale.providers : COMPAT
java.naming.factory.initial : org.apache.naming.java.javaURLContextFactory
java.naming.factory.url.pkgs : org.apache.naming
java.protocol.handler.pkgs : org.apache.catalina.webresources
java.runtime.name : OpenJDK Runtime Environment
java.runtime.version : 21.0.1
java.specification.name : Java Platform API Specification
java.specification.vendor : Oracle Corporation
java.specification.version : 21
java.util.logging.config.file : /opt/atlassian-jira-software-9.11.3/conf/logging.properties
java.util.logging.manager : org.apache.juli.ClassLoaderLogManager
java.vendor : Homebrew
java.vendor.url : https://github.com/Homebrew/homebrew-core/issues
java.vendor.url.bug : https://github.com/Homebrew/homebrew-core/issues
java.vendor.version : Homebrew
java.version : 21.0.1
java.version.date : 2023-10-17
java.vm.compressedOopsMode : Zero based
java.vm.info : mixed mode, sharing
java.vm.name : OpenJDK 64-Bit Server VM
java.vm.specification.name : Java Virtual Machine Specification
java.vm.specification.vendor : Oracle Corporation
java.vm.specification.version : 21
java.vm.vendor : Homebrew
java.vm.version : 21.0.1
jdk.debug : release
jdk.tls.ephemeralDHKeySize : 2048
log4j2.contextSelector : org.apache.logging.log4j.core.selector.BasicContextSelector
log4j2.disableJmx : true
log4j2.garbagefree.threadContextMap : true
log4j2.isWebapp : false
mail.mime.decodeparameters : true
native.encoding : UTF-8
org.apache.catalina.security.SecurityListener.UMASK : 0027
org.apache.el.GET_CLASSLOADER_USE_PRIVILEGED : false
org.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER : true
org.dom4j.factory : com.atlassian.core.xml.InterningDocumentFactory
os.arch : aarch64
os.name : Mac OS X
os.version : 14.0
package.access : sun.,
org.apache.catalina.,
org.apache.coyote.,
org.apache.jasper.,
org.apache.tomcat.
package.definition : sun.,
java.,
org.apache.coyote.,
org.apache.jasper.,
org.apache.naming.,
org.apache.tomcat.
server.loader :
shared.loader :
socksNonProxyHosts : local|*.local|169.254/16|*.169.254/16
stderr.encoding : UTF-8
stdout.encoding : UTF-8
sun.arch.data.model : 64
sun.boot.library.path : /opt/homebrew/Cellar/openjdk/21.0.1/libexec/openjdk.jdk/Contents/Home/lib
sun.cpu.endian : little
sun.io.unicode.encoding : UnicodeBig
sun.java.command : org.apache.catalina.startup.Bootstrap start
sun.java.launcher : SUN_STANDARD
sun.jnu.encoding : UTF-8
sun.management.compiler : HotSpot 64-Bit Tiered Compilers
tomcat.util.buf.StringCache.byte.enabled : true
tomcat.util.scan.StandardJarScanFilter.jarsToScan : log4j-taglib*.jar,
log4j-web*.jar,
log4javascript*.jar,
slf4j-taglib*.jar
tomcat.util.scan.StandardJarScanFilter.jarsToSkip : annotations-api.jar,
ant-junit*.jar,
ant-launcher*.jar,
ant*.jar,
asm-*.jar,
aspectj*.jar,
bcel*.jar,
biz.aQute.bnd*.jar,
bootstrap.jar,
catalina-ant.jar,
catalina-ha.jar,
catalina-ssi.jar,
catalina-storeconfig.jar,
catalina-tribes.jar,
catalina.jar,
cglib-*.jar,
cobertura-*.jar,
commons-beanutils*.jar,
commons-codec*.jar,
commons-collections*.jar,
commons-compress*.jar,
commons-daemon.jar,
commons-dbcp*.jar,
commons-digester*.jar,
commons-fileupload*.jar,
commons-httpclient*.jar,
commons-io*.jar,
commons-lang*.jar,
commons-logging*.jar,
commons-math*.jar,
commons-pool*.jar,
derby-*.jar,
dom4j-*.jar,
easymock-*.jar,
ecj-*.jar,
el-api.jar,
geronimo-spec-jaxrpc*.jar,
h2*.jar,
ha-api-*.jar,
hamcrest-*.jar,
hibernate*.jar,
httpclient*.jar,
icu4j-*.jar,
jasper-el.jar,
jasper.jar,
jaspic-api.jar,
jaxb-*.jar,
jaxen-*.jar,
jaxws-rt-*.jar,
jdom-*.jar,
jetty-*.jar,
jmx-tools.jar,
jmx.jar,
jsp-api.jar,
jstl.jar,
jta*.jar,
junit-*.jar,
junit.jar,
log4j*.jar,
mail*.jar,
objenesis-*.jar,
oraclepki.jar,
org.hamcrest.core_*.jar,
org.junit_*.jar,
oro-*.jar,
servlet-api-*.jar,
servlet-api.jar,
slf4j*.jar,
taglibs-standard-spec-*.jar,
tagsoup-*.jar,
tomcat-api.jar,
tomcat-coyote.jar,
tomcat-dbcp.jar,
tomcat-i18n-*.jar,
tomcat-jdbc.jar,
tomcat-jni.jar,
tomcat-juli-adapters.jar,
tomcat-juli.jar,
tomcat-util-scan.jar,
tomcat-util.jar,
tomcat-websocket.jar,
tools.jar,
unboundid-ldapsdk-*.jar,
websocket-api.jar,
wsdl4j*.jar,
xercesImpl.jar,
xml-apis.jar,
xmlParserAPIs-*.jar,
xmlParserAPIs.jar,
xom-*.jar
user.country : KR
user.dir : /opt/atlassian-jira-software-9.11.3
user.home : /Users/snehaagarwal
user.language : en
user.name : snehaagarwal
user.timezone : Asia/Seoul
2023-11-26 17:46:58,007+0900 JIRA-Bootstrap INFO [c.a.jira.startup.TemporaryDirectoryCleaner] Cleaning the temporary directory located at /opt/atlassian-jira-software-9.11.3/temp
2023-11-26 17:46:58,009+0900 JIRA-Bootstrap INFO [c.a.jira.startup.TemporaryDirectoryCleaner] Finished cleaning the temporary directory.
26-Nov-2023 17:46:58.040 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"]
26-Nov-2023 17:46:58.053 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in [3400] milliseconds
2023-11-26 17:46:58,165+0900 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger] Running Jira startup checks.
2023-11-26 17:46:58,165+0900 JIRA-Bootstrap FATAL [c.a.jira.startup.JiraStartupLogger] Startup check failed. Jira will be locked.
2023-11-26 17:46:58,219+0900 JIRA-Bootstrap INFO [c.a.jira.startup.LauncherContextListener] Startup is complete. Jira is ready to serve.
2023-11-26 17:46:58,220+0900 JIRA-Bootstrap INFO [c.a.jira.startup.LauncherContextListener] Memory Usage:
Heap memory : Used: 239 MiB. Committed: 384 MiB. Max: 2048 MiB
TOTAL : Used: 289 MiB. Committed: 488 MiB. Max: 3584 MiB
26-Nov-2023 17:59:05.303 INFO [main] org.apache.catalina.core.StandardServer.await A valid shutdown command was received via the shutdown port. Stopping the Server instance.
26-Nov-2023 17:59:05.307 INFO [main] org.apache.coyote.AbstractProtocol.pause Pausing ProtocolHandler ["http-nio-8080"]
26-Nov-2023 17:59:05.307 INFO [main] org.apache.catalina.core.StandardService.stopInternal Stopping service [Catalina]
2023-11-26 17:59:05,316+0900 main INFO [c.a.jira.startup.DefaultJiraLauncher] Stopping launchers
26-Nov-2023 17:59:05.613 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@72288480]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.613 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@6c19769c]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.613 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@434d001d]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.614 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@4db16677]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.614 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@6abb44cb]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.614 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@41ddec69]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.614 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@5e3cb58e]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.614 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@18f8e2e0]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.614 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@28d56028]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.614 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@6c56fff]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.615 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@3dee3a6c]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.615 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@62de20d3]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.615 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@6109d880]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.615 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@4c9ef9c9]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.615 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@6f976c]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.615 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@1324e70a]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.615 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@3cc6f036]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.615 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@72d16d6]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.615 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@7b0525a8]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.615 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@4f2d8175]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.615 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@44618fe6]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.616 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@2b15ba1a]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.616 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@796fe2b5]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.616 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@5a6af2c4]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.616 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@5a537a16]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@123c48d0]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
26-Nov-2023 17:59:05.619 INFO [main] org.apache.coyote.AbstractProtocol.stop Stopping ProtocolHandler ["http-nio-8080"]
26-Nov-2023 17:59:05.622 INFO [main] org.apache.coyote.AbstractProtocol.destroy Destroying ProtocolHandler ["http-nio-8080"]
26-Nov-2023 17:59:12.614 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version name: Apache Tomcat/9.0.82
26-Nov-2023 17:59:12.615 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Oct 11 2023 13:15:08 UTC
26-Nov-2023 17:59:12.615 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version number: 9.0.82.0
26-Nov-2023 17:59:12.615 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Mac OS X
26-Nov-2023 17:59:12.615 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 14.0
26-Nov-2023 17:59:12.615 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: aarch64
26-Nov-2023 17:59:12.615 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: /opt/homebrew/Cellar/openjdk/21.0.1/libexec/openjdk.jdk/Contents/Home
26-Nov-2023 17:59:12.615 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 21.0.1
26-Nov-2023 17:59:12.615 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Homebrew
26-Nov-2023 17:59:12.615 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: /opt/atlassian-jira-software-9.11.3
26-Nov-2023 17:59:12.615 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: /opt/atlassian-jira-software-9.11.3
26-Nov-2023 17:59:12.619 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.lang=ALL-UNNAMED
26-Nov-2023 17:59:12.619 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.io=ALL-UNNAMED
26-Nov-2023 17:59:12.619 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.util=ALL-UNNAMED
26-Nov-2023 17:59:12.619 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.util.concurrent=ALL-UNNAMED
26-Nov-2023 17:59:12.619 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED
26-Nov-2023 17:59:12.619 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=/opt/atlassian-jira-software-9.11.3/conf/logging.properties
26-Nov-2023 17:59:12.619 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
26-Nov-2023 17:59:12.619 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms384m
26-Nov-2023 17:59:12.619 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx2048m
26-Nov-2023 17:59:12.619 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:InitialCodeCacheSize=32m
26-Nov-2023 17:59:12.619 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:ReservedCodeCacheSize=512m
26-Nov-2023 17:59:12.619 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dlog4j2.contextSelector=org.apache.logging.log4j.core.selector.BasicContextSelector
26-Nov-2023 17:59:12.619 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dlog4j2.disableJmx=true
26-Nov-2023 17:59:12.619 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dlog4j2.garbagefree.threadContextMap=true
26-Nov-2023 17:59:12.619 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dlog4j2.isWebapp=false
26-Nov-2023 17:59:12.619 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.awt.headless=true
26-Nov-2023 17:59:12.619 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Datlassian.standalone=JIRA
26-Nov-2023 17:59:12.619 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true
26-Nov-2023 17:59:12.619 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dmail.mime.decodeparameters=true
26-Nov-2023 17:59:12.619 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.dom4j.factory=com.atlassian.core.xml.InterningDocumentFactory
26-Nov-2023 17:59:12.620 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:-OmitStackTraceInFastThrow
26-Nov-2023 17:59:12.620 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.locale.providers=COMPAT
26-Nov-2023 17:59:12.620 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Datlassian.plugins.startup.options=
26-Nov-2023 17:59:12.620 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djdk.tls.ephemeralDHKeySize=2048
26-Nov-2023 17:59:12.620 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.protocol.handler.pkgs=org.apache.catalina.webresources
26-Nov-2023 17:59:12.620 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.apache.catalina.security.SecurityListener.UMASK=0027
26-Nov-2023 17:59:12.620 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xlog:gc*:file=/opt/atlassian-jira-software-9.11.3/logs/atlassian-jira-gc-%t.log:tags,time,uptime,level:filecount=5,filesize=20M
26-Nov-2023 17:59:12.620 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+ExplicitGCInvokesConcurrent
26-Nov-2023 17:59:12.620 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dignore.endorsed.dirs=
26-Nov-2023 17:59:12.620 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=/opt/atlassian-jira-software-9.11.3
26-Nov-2023 17:59:12.620 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=/opt/atlassian-jira-software-9.11.3
26-Nov-2023 17:59:12.620 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=/opt/atlassian-jira-software-9.11.3/temp
26-Nov-2023 17:59:12.626 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The Apache Tomcat Native library which allows using OpenSSL was not found on the java.library.path: [/Users/snehaagarwal/Library/Java/Extensions:/Library/Java/Extensions:/Network/Library/Java/Extensions:/System/Library/Java/Extensions:/usr/lib/java:.]
26-Nov-2023 17:59:12.793 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8090"]
26-Nov-2023 17:59:12.799 INFO [main] org.apache.catalina.startup.Catalina.load Server initialization in [299] milliseconds
26-Nov-2023 17:59:12.805 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service [Catalina]
26-Nov-2023 17:59:12.805 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet engine: [Apache Tomcat/9.0.82]
2023-11-26 17:59:15,808+0900 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger]
Jira starting...
2023-11-26 17:59:15,846+0900 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger]
Free Memory : 270MB
Used Memory : 114MB
Memory Pool: CodeHeap 'non-nmethods' : CodeHeap 'non-nmethods': init = 5849088(5712K) used = 1503744(1468K) committed = 5849088(5712K) max = 5849088(5712K)
Memory Pool: Metaspace : Metaspace: init = 0(0K) used = 25982240(25373K) committed = 26345472(25728K) max = -1(-1K)
Memory Pool: CodeHeap 'profiled nmethods' : CodeHeap 'profiled nmethods': init = 33554432(32768K) used = 11650048(11377K) committed = 33554432(32768K) max = 265502720(259280K)
Memory Pool: Compressed Class Space : Compressed Class Space: init = 0(0K) used = 2849440(2782K) committed = 3014656(2944K) max = 1073741824(1048576K)
Memory Pool: G1 Eden Space : G1 Eden Space: init = 24117248(23552K) used = 81788928(79872K) committed = 246415360(240640K) max = -1(-1K)
Memory Pool: G1 Old Gen : G1 Old Gen: init = 378535936(369664K) used = 31344440(30609K) committed = 148897792(145408K) max = 2147483648(2097152K)
Memory Pool: G1 Survivor Space : G1 Survivor Space: init = 0(0K) used = 7126912(6959K) committed = 7340032(7168K) max = -1(-1K)
Memory Pool: CodeHeap 'non-profiled nmethods' : CodeHeap 'non-profiled nmethods': init = 33554432(32768K) used = 2723200(2659K) committed = 33554432(32768K) max = 265519104(259296K)
jdk.debug : release
os.arch : aarch64
os.name : Mac OS X
os.version : 14.0
org.apache.coyote.,
org.apache.jasper.,
org.apache.tomcat.
java.,
org.apache.coyote.,
org.apache.jasper.,
org.apache.naming.,
org.apache.tomcat.
server.loader :
shared.loader :
log4j-web*.jar,
slf4j-taglib*.jar
ant-junit*.jar,
ant-launcher*.jar,
ant*.jar,
asm-*.jar,
aspectj*.jar,
bcel*.jar,
biz.aQute.bnd*.jar,
bootstrap.jar,
catalina-ant.jar,
catalina-ha.jar,
catalina-ssi.jar,
catalina.jar,
cglib-*.jar,
cobertura-*.jar,
commons-codec*.jar,
commons-daemon.jar,
commons-dbcp*.jar,
commons-io*.jar,
commons-lang*.jar,
commons-math*.jar,
commons-pool*.jar,
derby-*.jar,
dom4j-*.jar,
easymock-*.jar,
ecj-*.jar,
el-api.jar,
h2*.jar,
ha-api-*.jar,
hamcrest-*.jar,
hibernate*.jar,
httpclient*.jar,
icu4j-*.jar,
jasper-el.jar,
jasper.jar,
jaspic-api.jar,
jaxb-*.jar,
jaxen-*.jar,
jaxws-rt-*.jar,
jdom-*.jar,
jetty-*.jar,
jmx-tools.jar,
jmx.jar,
jsp-api.jar,
jstl.jar,
jta*.jar,
junit-*.jar,
junit.jar,
log4j*.jar,
mail*.jar,
objenesis-*.jar,
oraclepki.jar,
org.junit_*.jar,
oro-*.jar,
servlet-api-*.jar,
servlet-api.jar,
slf4j*.jar,
tagsoup-*.jar,
tomcat-api.jar,
tomcat-coyote.jar,
tomcat-dbcp.jar,
tomcat-i18n-*.jar,
tomcat-jdbc.jar,
tomcat-jni.jar,
tomcat-juli.jar,
tomcat-util.jar,
tools.jar,
websocket-api.jar,
wsdl4j*.jar,
xercesImpl.jar,
xml-apis.jar,
xmlParserAPIs.jar,
xom-*.jar
user.country : KR
user.language : en
2023-11-26 17:59:15,852+0900 JIRA-Bootstrap INFO [c.a.jira.startup.TemporaryDirectoryCleaner] Cleaning the temporary directory located at /opt/atlassian-jira-software-9.11.3/temp
2023-11-26 17:59:15,853+0900 JIRA-Bootstrap INFO [c.a.jira.startup.TemporaryDirectoryCleaner] Finished cleaning the temporary directory.
Andy Heinzer
November 29, 2023
It looks like you're using an unsupported Java version that is newer than the supported platforms.  Try using an OpenJDK 11 or 17 version on your system.  I would also recommend following the steps in Installing Java to set the JAVA HOME environmental variable so that when Jira starts, it uses that specific Java environment.
