NOT IN searches taking ages on JIRA
Rahul Aich [Nagra]
March 31, 2014
Hi
I am on jira 5.0.
I did a full re-index of database this morning.
After that when i do searches it is all fine, however the moment i perform searches with clause project NOT IN("aaa","bbb"), the search takes minutes and still doesn ot return any results
What could be causing this issue?
How can i fix this?
Rahul
Tarun Sapra
Can you try deleting indexes folder and then doing a re-indexing again instead of just re-indexing without first deleting.
Rahul Aich [Nagra]
April 2, 2014
Yes reindex with deleting folder resolved the issue.
Andris Grinbergs
March 31, 2014
It seams like "Project not in" should return many issues - maybe it is out of memory issue.... Is there any errors in LOGs?
Rahul Aich [Nagra]
March 31, 2014
No errors and it was supposed to return 100 records. Any ideas why it may be taking long?
Andris Grinbergs
March 31, 2014
Have you tried another reindexing? Maybe reindex failed... Is database ok?
