I have the following Issue Filter in JQL which gives me my backlog by rank order:
project = XXX and (type = Story or type = bug) and status != Closed order by rank asc
I'd like to have an equivilant SQL query so I can pull the same data directly in to an Excel spreadsheet. I know "Rank" is a linked list which requires some sort of a recursive SQL query.
Can anybody provide and example so I don't have to wrack my brain trying to figure this out myself.
This will give you a list of all the ids of the requested jiraissues and their current ranking:
select i.id,r.id from jiraissue i, AO_60DB71_ISSUERANKING r, project p where i.id=r.issue_id and i.PROJECT=p.id and p.PKEY = 'JC' and i.ISSUESTATUS not in (select id from ISSUESTATUS where pname in ('Closed')) and i.ISSUETYPE not in (select id from ISSUETYPE where PNAME in ('Story','Bug')) order by r.id;
Just change the 'JC' to your own project key.
should be
... and i.ISSUETYPE in (select ...
(remove the not)
since you want Story and Bug
While this SQL works, it's not what I need. I'm not sure what it's giving me, but the list I get back doesn't match the backlog in Greenhopper. I thought since RANK is a linked list you couldn't just order by RANK.id?
SQL for JIRA does the job. Simply perform a query similar to this:
select * from issues where JQL='project = XXX and (type = Story or type = bug) and status != Closed order by rank asc'
Simple?
Of course, you have to read the plug-in documentation in order to learn hot to export to a CSV format, but it is pretty easy too!
Why don't you just export your JQL results in Excel?
