Need a guideline to run the project management using JIRA
Michelle Lee
September 23, 2021
To my understanding, JIRA used to manage software development as part of the project management tool using agile methodology.
However, I am running the Hybrid mode of the project management, is JIRA a good tool to track all the project according to the timeline and tasks, Does JIRA able to provide the project management reporting tool, e.g. burned down chart, status tracking reporting.
Jacob Vu
September 23, 2021
Hi @Michelle Lee
As the other two posts mentioned, there are definitely resources that help you get started but there's a lot to cover when it comes to project management in JIRA.
You're able to manage projects both using Agile and Waterfall methods and I'd suggest looking at tools like Roadmaps, Advanced Roadmaps, etc. to help build schedules, reports and burn-down charts.
If you're looking for expert help, this is something that my organization specializes in and can help guide you to using JIRA for project management. Take a look at our blogs here for some more resources on using Advanced Roadmaps, Roadmaps and project management in JIRA.
Jacob
G subramanyam
Hi @Michelle Lee welcome to the Atlassian community.
You are in the right place and the tool to use for your reporting requirements.
Here's the needed information:
Jira guide
Getting started basics
While the answer to your question will be lengthy, checking those 2 links will give a holistic view. And Yes, Jira software has inbuilt Agile reporting tools. When combined with Confluence, you can completely track the project end to end.
