Hello Team,
As per the current setup in Jira if we provide the estimates to any issue the total given estimates are shown in the original estimates field.
But, we want a separate fields where we can add separately track time for both dev and qa and then the total will show in original estimates.
Say for eg,
Dev- 8h
QA-4h
total will be 12 hrs in the original estimates field but separate time given should also be there
is it possible?
Hi @Saudamini Deshmukh
It's Mary from Planyway for Jira
Yes, it's possible to achieve this in Jira by creating custom fields for Development (Dev) and Quality Assurance (QA) time estimates and then either manually updating the Original Estimate field based on these values or using automation to sum the Dev and QA estimates and populate the Original Estimate field automatically. Here's how you can approach this:
First, you need to create custom fields for tracking Development and QA time separately.
Once the custom fields are set up, users can manually enter estimates into the "Dev Time Estimate" and "QA Time Estimate" fields. They would then need to manually sum these values and enter the total into the Original Estimate field for the issue.
For a more automated approach, you can use Jira's automation features (available in Jira Cloud and Jira Server/Data Center via plugins like ScriptRunner or Automation for Jira).
Here’s a basic outline on setting up automation in Jira Cloud:
If you consider using a plugin, I would suggest ActivityTimeline in your case. In addition to standard time logging in ActivityTimeline, users get the opportunity to assign the work log to a certain category of work.
It is possible to generate Timeline & Detailed Timesheet reports and group the data by Category so that you can understand how much time is getting consumed by each type of work.
For this go to Track module->Open 'Advanced' tab and choose Group by Category:
If you have any additional questions, please feel free to ask me. We can provide a free demo session if you need it.
Hi @Saudamini Deshmukh ,
Can you please refer this question How to create custom time tracking fields in Jira?
Bhushan
