×Hi All,
I am new to Jira automation and i have the requirement of to complete the following -
We 4 Numeric value custom fields in Jira cloud and i need help with creating an automation rule to get the highest value of the first 3 fields to be populated on the 4th field.
Example:
Field 1 - Drop down values 1,2,3,4,5
Selected value - 4
Field 2 - Drop down values 1,2,3,4,5
Selected value - 1
Field 3 - Drop down values 1,2,3,4,5
Selected value - 5
Field 4 - Drop down values 1,2,3,4,5
Need the value of "Field 3" which is 5, as that is the highest value from the above 3 fields
Any guidance here will be very helpful, thank you in advance
Hi @RNV Jira1 and welcome to the community!
Try the following, it worked for me:
{{#=}}max({{issue.fields.NumSel1}},{{issue.fields.NumSel2}},{{issue.fields.NumSel3}}){{/}}
Alex
Hi, @RNV Jira1
Another solution, you can check if you're comfortable with Marketplace plugins, is Business Process Manager add-on, developed by my team.
For solving your case use Form Logic with if/then rules. Here is an example:
Hi @RNV Jira1 Welcome to Atlassian Community!
Are these (Field 1, Field 2, Field 3 and Field 4) number fields or single select list fields?
V.Y
