×We need your help in merging 2 JIRA instances Server(IP and QZ) into R2020 JIRA Cloud. Below table has details for all 3 types. Plan is to have cost effective model, simplify usage and have only one JIRA for all.
Hi Syedu,
welcome to Atlassian Community!
Although there was no table with details I'd recommend you to review resources on Cloud migrations first:
https://www.atlassian.com/migration/cloud
Merging two instances is an ambitious goal. Probably you need to have a bigger team to plan and execute your plan entirely.
https://confluence.atlassian.com/jirakb/merge-multiple-instances-of-jira-cloud-779160767.html
Those are the information for the high level plan. I recommend you to check with a dedicated Jira Partner for migrations probably to work out a thorough plan - in case of any specific questions you also can refer to Atlassian Community:
https://community.atlassian.com/t5/Atlassian-Cloud-Migration/ct-p/atlassian-cloud-migration
Daniel
