Hi All,
This is the first time i am writing an query.In case if my query is not clear, please let me know.
Question : My requirement here is to identify the configuration - specifically the Element Checklist configuration of a project and to apply the same set of configuration to other projects..Say if I have created a Project A with some set of element checklist (say element checklist1, 2....) .For another project B i want the same set of configuration.
Is it possible to import the same configuration of Element Checklist from Project A to Project B. Or is there any way to access the DB tables and see the configuration and create a replica. Both ways is fine for me.
The Goal here is to reduce the time from my end and do the configuration in minimal time, Say if we have 20-30 element checklist, creating the same elements check list for N number of projects (N element checklist * N Project.)
Hope i do get valuable and positive responses.
Thanks in advance,
Rahul M G
It is not currently possible with Elements Checklist to copy templates from one project to another.
If you would like to vote or watch the change request on the Elements Support portal, you can check it out here: https://support.elements-apps.com/browse/CL-40
Laura
