I would like to understand the use of this option in jira7.2.1
Enable HTML in custom field descriptions and list item values | ON |
Can someone explain me with example, how this works or helps please.
Hello Ranganath!
In this knowledge base, you should find all the information related to custom fields:
https://confluence.atlassian.com/display/AdminJIRAServer072/Configuring+a+custom+field
Let me summarize the information related to your question:
Hope that helps!
Regards
