Need help while importing the CSV file of issues in JIRA
Shriya Chhajed
HI,
I am facing the issue while i try to import the issues in JIRA. The Jira version is very old, but i would like to import the issues on similar version and then will try upgrading it.
I am facing the issue something related to double quotes, which i am not able to recognize from where it should be removed/added/modified.
Please find the attach screenshot for the same and help me with this.
The source and destination Jira Version is 4.4.5Jira import issue of double quotes.pngThanks and Regards
Shriya Chhajed
Fayaz Abdul
Hi @Shriya Chhajed
Check that line in CSV file or better to delete it if not required, save the CSV file and try to import.
This works for me.
Fayaz
Prashant Mali
July 10, 2018
Hi @Shriya Chhajed ,
The file imported needs to have a valid CSV file format. Refer to Valid csv import .
Prashant
Shriya Chhajed
Hi Prashant,
The file has the valid csv format.
Thanks and Regards
Shriya Chhajed
Kirubel Tesfaye
July 10, 2018
Hi @Shriya Chhajed,
This is caused when some characters in your csv file may be used as a delimiter for the JIRA import tool. I will suggest opening this file in some text editor of your choice to find out which character is causing the issue and make the change accordingly.
hope this helps!
Shriya Chhajed
Hi Kirubel,
Thanks for your response.
Yeah, i tried doing the same but i am still facing the issue. I have replied the same here
Thanks and Regards
Shriya Chhajed
Grigory Salnikov
July 10, 2018
Hi!
Please, check this article and the answer provided by @Jerome Chadee.
Shriya Chhajed
Hi Greg,
Thank you for your response.
I read the article and have replied @Jerome Chadee on his answer.
Thanks and Regards
Shriya Chhajed
