Need help with Atlassian email handlers
Warren McInnes
July 3, 2013
Hi All.
As per the title I need help with Atlassian email handlers.
We mostly use the "Create a new issue or add a comment to an existing issue" but need the feature of "Add a comment before a specified marker or separator in the email body" to use the Regex to remove old email replies from comments via email?
So basically we need the functionality to create and comment via email to jira, but also need to strip out old email reply?
Is there any way?
This is the regex i'm using -
  • Split Regex: /From: *|___.*|On .*wrote:|----Orig.*|On .*(JIRA).*/
Thanks In Advance
Warren
Dipti Ranjan Behera
July 3, 2013
Hi Warren,
you can write custom email handler plugins. And you can use this logic of stripping there.
And again you can also do new add-on to the functionality , if you want.
https://developer.atlassian.com/display/JIRADEV/Plugin+Tutorial+-+Writing+a+Custom+Message+(Mail)+Handler+for+JIRA
Warren McInnes
July 3, 2013
Thank you, I will have a look into this option.
Dipti Ranjan Behera
July 3, 2013
Hi Warren,
This should help you a lot in writing the plugin :
https://bitbucket.org/atlassian/tutorial-jira-add-email-handler/src
Peter Van de Voorde
I think JEMH offers this functionality : https://marketplace.atlassian.com/plugins/com.javahollic.jira.jemh-ui
I don't know if this is possible with the basic mail handlers.
Best regards,
Peter
Warren McInnes
July 3, 2013
This will not work for our company as we do not have budget for paid plugins.
Nitram
July 3, 2013
The following plugin
JIRA Advanced Mail Handler
which you can find from atlassian market place may help you, or other wise look into this link
https://confluence.atlassian.com/display/JIRA/Creating+Issues+and+Comments+from+Email
Hope this Helps!
Warren McInnes
July 3, 2013
Sorry Nitram...This option is too old and seems there is no support for this plugin, Thanks
Nitram
July 3, 2013
Have you looked into this one too https://confluence.atlassian.com/display/JIRA/Creating+Issues+and+Comments+from+Email
check whether it helps u.
Warren McInnes
July 3, 2013
Hi Nitram, Sorry not helping...thanks
Deleted user October 1, 2013
Its interesting, you seem to want a 'current' plugin, and support, but dont wan't to pay for it. Somethings got to give...
Warren McInnes
October 1, 2013
@Andy Brook,
"Something's got to give..." Yes, indeed, We would love you use JEMH...But in the company I work for we do not have budget for your "Paid" Plugin, So therefore I have to look for alternatives until such time.
I hope this clears things up between us. I still dont have a solution to removing images coming into to JIRA via email signitures such as your md5 method, but until I find a method which is free/not costly will just won't have such features.
There's a possibility I may have figured out a method to adding due dates via emails automatially, how ever I am still in testing.
So please understand why I have to look for alternatives.
Kind Regards,
Warren
