Need help with jira automation and aws sns
PATEL,VRAJ
July 9, 2025
I’d like to set up an automation rule in Jira that sends an email notification using aws sns every time a new issue is created and appears on a specific Jira dashboard. I’m not sure how to configure this using Jira Automation.
Aron Gombas _Midori_
Related here, you can send the dashboard itself in an email, as well! It may be a viable alternative to solve your use case.
This is how it looks in your email client:
... and then in the PDF:
Links:
  1. https://midori-global.com/products/better-pdf-automation-for-jira/cloud/documentation/configure-automation/send-pdf#send-by-cron
  2. https://midori-global.com/products/better-pdf-automation-for-jira/cloud/documentation/configure-automation/#dashboards
(Discl. this app is developed by our team.)
Trudy Claspill
Hello @PATEL,VRAJ
Have you seen this documentation?
https://support.atlassian.com/cloud-automation/docs/configure-aws-sns-for-jira-automation/
