×I have tests that run everyday, but there could be chances they are run multiple times, but i want to grab just the latest run from the tests using this
issueType = 'Test Execution' and issue in testTestExecutions('testexec1' AND 'testexec2' AND 'testexec3')
but doesn't work, please help.
Thanks in advance,
Lakshmi
HI @LP S ,
What test management are you using and what error are you getting from the JQL?
The JQL for testTestExecution doesn't looks right. Take a look at the documentation.
https://docs.getxray.app/display/XRAY/Enhanced+querying+with+JQL
-Ben
Have you tried just the example with one Issue Key. Doesn't state you can display multiple tests. Only option for multiple test is with a test filter.
