×Hi,
Need to create a issue based on another issue for different issue type and link those issues in issue link.
For eg,
If we create a issue with Initiative type and summary CPM: "program name" then 4 issues should be created with Milestone issue type like below.
CPM: "program name" Feature Complete
CPM: "program name" Bug Free
CPM: "program name" SOP 1
CPM: "program name" SOP 2
After creation of the above 4 issues these 4 issues should be linked to issue link for Initiative issue type.
You can use Jira automation
Trigger: issue created
Condition: issue type initiative
Action: create tasks
Action: link to trigger issue with specific link
note: the rule must be created by the sys admin in the global administration since you are using multiple projects.
Hi @Fabian Lim , in our jira we are not using Jira Automation.
So, can you suggest alternative solution.
I think there is the lite version that you can try, but I cant remember if the automation I mention is possible.
Other options are using a plugin. Jmwe, scritprunner, powerscripts are some of them. Check the marketplace.
Regards
