Need to customize Jira Home page
Pearson Tech India IT Team April 29, 2014
Hi Team,
customize the JIRA home page and add information so that users know whom to contact in case of issues with their login or other jira related queries
Shankar.chintala.
Fabio Racobaldo _Catworkx_
you need to be an administrator and go to JIra Administartion -> System -> Edit Settings and update Introduction at your convenience as html.
Moreover, if you need to add some info as Banner you can add HTML code into JIRA Administration -> System -> Announcement Banner
Hope this helps,
Fabio
Hi Fabio,
Please find the scan shot ,below introduction i need to add table in that table i want to add some content,Please do needfull.
Nic Brough -Adaptavist-
April 29, 2014
You need to do exactly what Fabio has already described - go into the Admin section -> System -> Settings and edit the value set for "introduction"
When you go in there, you'll see it already has the line of text you can see in the introduction box.
Hi Team,
Thanks for your support,It's working fine.
Shankar.chintala.
you're welcome. Please mark this question as accepted.
Nic, thanks for your support on this answer.
Fabio
April 29, 2014
I'd add a "text gadget" to the system dashboard, containing the details you need - it will appear to non-logged in users hitting the main home page. (You may need to enable the gadget in the list of installed plugins)
