Need to export all issues and attachments from Jira and import to Azure
Vani Rudraraju November 27, 2024
Hi Team,
we have to export all issues and attachemnts from Jira and with field mapping we need to import this issues and attachments to Azure , may i know the possibility way please
Christophe De Beule
Hi @Vani Rudraraju
I hope you are doing well.
My name is Christophe, and I’m a Solution Engineer at Exalate.
Exalate allows you to seamlessly migrate your issues from Jira to Azure DevOps. Our solution features a unique decentralized approach to integrating work systems, ensuring each side of the connection retains full autonomy.
To make things easier, you can set up triggers to automatically sync all relevant Jira issues to your Azure DevOps (ADO) instance. You have complete control over which specific issues are synced and the data they carry whether it’s the summary, description, attachments, comments, assignee, or more. Exalate handles it all effortlessly.
Setting up Exalate is straightforward, and you can customize it to meet your exact needs.
If you would like to see a customized demo of the product, don't hesitate to book a slot with us.
Christophe De Beule
