Need to track moved sprints, can I use a LABEL for that?
PJ Maman September 5, 2024
Will a LABEL do the job of TRACKING moved ISSUES?
Shikha Verma
September 5, 2024
Hi @PJ Maman, If I understand you correctly, you can use labels to track moved issues, but it will require some manual effort or automation.
Whenever an issue is moved (to a different sprint, project, or backlog), you or your team members can manually add a specific label, like "moved-issue" to that issue. And then
you can create a JQL query to filter all issues with this label to monitor and track them.
JQL:  labels = "moved-issue"
PJ Maman September 15, 2024
Correct i used sprint rollover as a label.  Ideally when issue is closed either “delete” the label which I don’t like to do or rollover closed.
Chris Rainey
Hi PJ,
Can you elaborate more on what you mean by moved issues? What information are you trying to capture here?
Very simple!  Tracking issues that were moved to another sprint
Chris Rainey
Moved as a result of the issue still being unresolved at the time of the sprint ending?
karim -Atlassway-
Banned
September 15, 2024
Hi @Shikha Verma ,
As alternative you can use Colored Label Manager reports to track issues progress.
Atlassway Team
Regards
FREE
