Needs help on Jira 4.4 upgrade from jira 4.3
Sudarshan Bisht
August 6, 2011
I have installed jira 4.3 with evaluation licenece and it is working fine. Now I want to upgrade it to Jira 4.4. I download the fbin ile but it is showing the following error
# ./atlassian-jira-4.4-x64.bin
Unpacking JRE ...
Starting Installer ...
/root/atlassian-jira-4.4-x64.bin.7057.dir/jre/bin/java: 1: Syntax error: "(" unexpected
I have disable all the plugins . But this is not running. Plz help
Kyeyeon Kim August 7, 2011
You are running x64 binary on 32bit system.
Try atlassian-jira-4.4-x32.bin
mlassau_atlassian
August 7, 2011
You should raise a support request on https://support.atlassian.com/
Include system details and full logs as suggested above.
Eva
August 7, 2011
And put the JIRA log file here would also help :)
Eva
August 7, 2011
What system are you installing on?
