No LDAP connection (host unreachable) after DC was shutdown
Annette Ruster January 31, 2020
Hi all
We had a Domain Controller.
Jira LDAP connection worked just fine (no SSL).
Then we added a second Domain Controller (isGC=true) and turned off the first domain controller.
The users can still login with their computers in the domain, but not in Jira.
Does Jira somewhere store the URL to the LDAP server or does it build every time a user tries to login?
From the log:
http-nio-8080-exec-12 ERROR anonymous 825x3920x1 1cj5ees 192.168.0.xx /rest/gadget/1.0/login [c.a.c.manager.application.ApplicationServiceGeneric] Directory 'Active Directory server' is not functional du ring authentication of 'user1'. Skipped.
Caused by: org.springframework.ldap.CommunicationException: DOMAIN.local:389; nested exception is javax.naming.CommunicationException: DOMAIN.local:389 [Root exception is java.net.NoRouteToHostException: No route to host
Caused by: java.net.NoRouteToHostException: No route to host (Host unreachable)
Andrew Laden
January 31, 2020
So what did/do you have in the "hostname" field of the user directory configuration? You had to have something there. Does whatever you have in there still respond to LDAP requests.
As Tony mentioned, you HAVE to have a local admin account that is not coming from the Directory. If for no other reason then the fact that you are not allowed you edit the directory settings for the directory you are logged in from. (which is a nice safety feature)
Annette Ruster February 3, 2020
hi @Andrew Laden
We have just "domainname" in the hostname field
I use an LDAP browser on my computer and it can see both servers.
Yes, we do have a local Jira administrator account. How else could we create the User Directory? ;)
So I suppose, I was right: Jira builds internally an LDAP connection string and stores it somewhere permanent in the database. And the only way, in this case, is to remove the User Directory and create it again.
Please correct me, if I'm wrong.
Andrew Laden
February 3, 2020
Try putting in the hostname of Domain Controller instead of the Domainname. Just to see.
Also try an LDAP browser from the Jira Server, not just your desktop to see if there is something going on at the network level.
On the "User Directory" Admin page, there is a link (near the bottom) "Directory Configuration Summary" That shows you the full information kept in the database.
check what it says for "ldap.url" that what is in the database.
Annette Ruster February 5, 2020
well, ldap.url has only the domain name with the port number.
I tried it with hostname, unsuccessful.
But the IP address of the Domain Controller works.
Whereby the ldapsearch on the Jira server behaves in the same way.
But that doesn't explain why it doesn't work with the Domain Name
Andrew Laden
February 5, 2020
Sounds like your host is having a name resolution problem, nothing to do with Jira.
Check your dns settings, etc. make sure that your old domain controller isn't listed in the /etc/hosts file for example.
Like Annette Ruster likes this
Exactly!
/etc/hosts contains the old DC
Thank you.
Andrew Laden
February 6, 2020
Great. Now you should get your server pointing to your AD DNS infrastructure so you never have to worry about this again. ;)
Glad its back to working for you.
Adrian Stephen
January 31, 2020
Hi @Annette Ruster
Have you imported the SSL certs into Jira's JAVA truststore? You may follow the steps here:
A Jira restart is required after importing the certs.
Adrian Stephen
Hi  @Adrian Stephen
As I mentioned: we don't use SSL
Nevertheless, I tried to restart Jira. This didn't help
Tony Rossiter
January 31, 2020
If you can’t get back in at all, bring that first DC back up and then go fix the URL
Tony Rossiter
January 31, 2020
Your LDAP connection was likely configured with the exact URL for the DC.  I would check the connection, fix the url and retest.
We have multiple DCs replicated to each other and get around this problem by using an alias in the LDAP connection.  This way they can easily take down one and not lose access.
I would also recommend setting up an account on the local directory with admin creds just in case something like this happens.   You don’t want to lose the ability to access the system as an admin.
That's the point: both servers have equal Naming Context and the hostname and base DN fields don't mention names of the servers.
Tony Rossiter
January 31, 2020
Sorry, missed that detail on first read.  Here's a troubleshooting guide that might help:
https://confluence.atlassian.com/jirakb/java-net-noroutetohostexception-in-ldap-connection-703398693.html
