I can't seem to find any controls to edit an issue in the New Jira Issue View.
Background: https://confluence.atlassian.com/jiracorecloud/the-new-jira-issue-view-938040503.html
The `e` shortcut from the old view also does not work in the new view.
Am I missing something?
Hi @Vuong V,
If you have edit permissions for specific fields on the issue, you should be able to edit them.
You can edit them by hovering over the a field and clicking on it, which should reveal UI to edit and update the field inline.
See this demo:
There is no way to edit fields in one screen in the new design, as explained on the new issue view help page:
You can also say goodbye to view and edit modes—just click a field to edit it inline.
Hope this helps.
Ah yes Thanks. I did miss that small but important line.
You might not have "Edit" permissions on the issue. Can you or the admin check the project permissions?
Thanks Jobin. I was expecting the old one page edit. I din't realise all the fields are now inline edits.
