hi,
Here's my code. I put the code into a groovy file not inline.
I got a JiraSoftwareFeature NoClassDefFoundError .
someone can help?
JIRA version:7.1.2
scriptrunner version:4.3.1
import .....
@WithPlugin("com.pyxis.greenhopper.jira")
@JiraAgileBean
JiraSoftwareFeatureService jiraSoftwareFeatureService
@BaseScript CustomEndpointDelegate delegate
doSomething(httpMethod: “GET", groups: ["jira-administrators"]) { MultivaluedMap queryParams, String body ->
def enabled = jiraSoftwareFeatureService.isFeatureEnabled(JiraSoftwareFeature.PARALLEL_SPRINTS)
return Response.ok(new JsonBuilder([abc : enabled]).toString()).build()
Greenhopper is a bundled plugin in JIRA 7.1.2, and version is 7.1.20.
I can't find the class com.atlassian.greenhopper.features.JiraSoftwareFeature, even in the JIRA Software source. I can find a JiraAgileFeatures class in the same package in the API docs (https://docs.atlassian.com/jira-software/6.7.12/com/atlassian/greenhopper/features/package-summary.html), but I'm not sure that's what you need.
Based on the enum property you're after (PARALLEL_SPRINTS), I think you want is https://docs.atlassian.com/jira-software/6.7.12/com/pyxis/greenhopper/jira/configurations/BetaFeatures.html.
I also can't seem to find any documentation for a JiraSoftwareFeatureService. That's probably just because parallel sprints is still in labs; the API is probably changing rapidly, and I just need a particular version of the source. Did you have another base you were working from to help you divine the API needed for parallel sprints?
hi, Jonny Carter. Thanks in advance.
I'm sure that I imported all the classes as possible as I can.
My imports :
import com.atlassian.greenhopper.features.JiraSoftwareFeature
import com.atlassian.greenhopper.service.configuration.JiraSoftwareFeatureService
import com.onresolve.scriptrunner.runner.customisers.JiraAgileBean
import com.onresolve.scriptrunner.runner.customisers.WithPlugin
import com.onresolve.scriptrunner.runner.rest.common.CustomEndpointDelegate
import groovy.json.JsonBuilder
import groovy.transform.BaseScript
import javax.ws.rs.core.MultivaluedMap
import javax.ws.rs.core.Response
Think you could include the whole code block, imports and all?
