Not able to change workiflow in project
Tech Admin - SK Finance Limited January 24, 2025
Dear Team,
Please find the screenshots for Project Configuration, i am not able change workflow
Walter Buggenhout
Hi @Tech Admin - SK Finance Limited,
Since this appears to be a team managed project, changing a workflow is done from Project Settings > Issue types
Select the issue type you want to show the workflow for and then click Edit Workflow near the top right of your screen.
Hope this helps!
Workflow Schemes showing Inactive
Hi Team
Walter Buggenhout
I see you already accepted my answer - so I guess you have already understood. But just for clarity: workflow schemes show as inactive when they are not linked to a project.
As I mentioned before: workflow schemes can only be associated with company managed projects (while yours is team managed).
this support article explains how you can manage workflow schemes - at the very end, it also mentions how to associate a workflow scheme with - once more - a company managed project.
I will check and confirm ?
Hi Walter,
Shalini Pradhan
January 24, 2025
Hello @Tech Admin - SK Finance Limited ,
Good day! :)
In team managed projects, to manage a workflow, you need to navigate to your concerned team managed project -> project settings -> Issue types -> Select an issue type and then click 'Edit Workflow'.
Screenshot 2025-01-24 at 2.32.16 PM.pngScreenshot 2025-01-24 at 2.32.37 PM.png
You can refer to the following document as well for more information
Thank you!
I am trying but i am not able to assigned new workflow here
Walter Buggenhout
Just guessing here that you created a new workflow in Jira Settings and are hoping to add that workflow to your team managed project?
If so, that won't work. Centrally created workflows are only available to connect to company managed projects via a workflow scheme. In team managed projects you can only edit the workflow in your project, linked to the issue type.
