Not able to connect JIRA
Abhijit Dongre June 3, 2019
2019-06-04 11:27:43,678 JIRA-Bootstrap INFO [c.a.j.config.database.SystemDatabaseConfigurationLoader] Reading database configuration from C:\Program Files\Atlassian\Application Data\JIRA\dbconfig.xml
2019-06-04 11:27:44,059 JIRA-Bootstrap ERROR [c.a.config.bootstrap.DefaultAtlassianBootstrapManager] Could not successfully test your database:
org.h2.jdbc.JdbcSQLException: General error: "java.lang.IllegalStateException: File corrupted in chunk 28589, expected page length =< 192, got 1728392960 [1.4.185/6]" [50000-185]
Abhijit Dongre June 9, 2019
Hi Dave, I am now succeed to connect JIRA and MySQL, also imported previous data.
But now once I logged into JIRA, it is showing error popup as "Your licenses' user limits are exceeded. Users may not be able to create issues until you have upgraded your licenses or reduced the number of users."
I have deleted user entry from database from tables: cwd_user, cwd_user_attributes, cwd_membership, app_user
But still it is showing same error, kindly refer screenshot
Abhijit Dongre June 12, 2019
Hi Dave, I have un-installed MySQL and installed 5.6 version and it worked fine, thanks.
Dave Bosman [Realdolmen]
June 3, 2019
Hi @Abhijit Dongre
Is this the first time that you are connecting to the database or is this a an existing setup?
Could you please give some extra context. What is the current setup (OS, DB)? what did you exactly do before getting this issue? What did you already try to solve this problem?
Regards
Dave
Abhijit Dongre June 4, 2019
Hi Dave,
kindly find below the details
1. This is not first time I am connecting to DB, it was properly working earlier but due to holidays, installed JIRA server was off for 3 days, but when we try to run again it started to give Database connectivity issue.
2. OS is Windows 10 and database is H2
3. Below steps I tried to resolve it, but still same issue
i. I have deleted files: .jira-home.lock, .bundled-plugins and .osgi-plugins by stopping and restarting Atlassian JIRA service
ii. Deleted Cache folder:  Atlassian\Application Data\JIRA\caches
Please refer below screenshot
June 4, 2019
Hi @Abhijit Dongre
I believe the steps you did to resolve it are not the problem.
But are you using it as a production instance or is it just to evaluate Jira?
The reason why i ask is because the internal H2 database is not really supported and should only be used for evaluating jira.
So everything was working before but after a stop - start it does not work anymore.
About your log entries.
This one confused me because if i would have to guess, it seems that there is a connection problem.
But then you have following entry that looks like you have a corrupted database.
So knowing what happend now it seems to me that you indeed have a corrupted database.
If you are using it as a production instance, I presume (hope) you have a backup of the data because this can not be fixed for as far as i know.
You should install a decent database like MySQL or Postgres. Connect Jira to the new database and import your backup again.
Regards
Dave
Abhijit Dongre June 5, 2019
Thanks Dave, for your analysis.
I will be grateful to you if you could guide me on below points
1. How to setup MYSQL/Postgres and how to connect it to JIRA
2. Where I can find backup and How to import it,
currently I am see exports under C:\Program Files\Atlassian\Application Data\JIRA\export and there are .zip files which contains activeobjects.xml and entities.xml
June 5, 2019
Hi @Abhijit Dongre
Do a web search for 'install mysql windows 10' and you will find tons of examples on how to install your database.
Following page will help you with the setup.
https://confluence.atlassian.com/adminjiraserver/connecting-jira-applications-to-mysql-5-6-938846854.html
Once you have the database setup, you can import the zip file in jira with the built in import functionality.
Regards
Dave
Abhijit Dongre June 6, 2019
Hi Dave, now I am able to connect JIRA with MySQL, but while importing data it is throwing exception as
SQL Exception while executing the following:DELETE FROM component (Table 'jiradb.component' doesn't exist)
JIRA version: Jira 8.1.0
MySQL Version: 5.6
MySQL Connectors:
mysql-connector-java-5.1.47.jar
mysql-connector-java-5.1.47-bin.jar
June 6, 2019
Hi @Abhijit Dongre
You will need to check your $JIRAHOME/log/atlassian-jira.log for a more detailed error.
Regards
Dave
2019-06-07 10:49:07,880 JiraImportTaskExecutionThread-1 ERROR anonymous 649x21x1 1iwhrv5 0:0:0:0:0:0:0:1 /secure/SetupImport.jspa [c.a.j.bc.dataimport.DefaultDataImportService] Error importing data: com.atlassian.jira.exception.DataAccessException: org.ofbiz.core.entity.GenericDataSourceException: Generic Entity Exception occurred in deleteByAnd (SQL Exception while executing the following:DELETE FROM component (Table 'jiradb.component' doesn't exist))
at com.atlassian.jira.ofbiz.DefaultOfBizDelegator.removeByAnd(DefaultOfBizDelegator.java:238)
at com.atlassian.jira.ofbiz.WrappingOfBizDelegator.removeByAnd(WrappingOfBizDelegator.java:131)
at com.atlassian.jira.bc.dataimport.DefaultDataImportService.removeAllEntities(DefaultDataImportService.java:1007)
at com.atlassian.jira.bc.dataimport.DefaultDataImportService.performImport(DefaultDataImportService.java:728)
at com.atlassian.jira.bc.dataimport.DefaultDataImportService.doImport(DefaultDataImportService.java:324)
at com.atlassian.jira.web.action.setup.DataImportAsyncCommand.unsafeCall(DataImportAsyncCommand.java:82)
at com.atlassian.jira.web.action.setup.DataImportAsyncCommand.call(DataImportAsyncCommand.java:64)
at com.atlassian.jira.web.action.setup.DataImportAsyncCommand.call(DataImportAsyncCommand.java:30)
at com.atlassian.jira.task.ImportTaskManagerImpl$TaskCallableDecorator.call(ImportTaskManagerImpl.java:176)
at com.atlassian.jira.task.ImportTaskManagerImpl$TaskCallableDecorator.call(ImportTaskManagerImpl.java:148)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Caused by: org.ofbiz.core.entity.GenericDataSourceException: Generic Entity Exception occurred in deleteByAnd (SQL Exception while executing the following:DELETE FROM component (Table 'jiradb.component' doesn't exist))
at org.ofbiz.core.entity.GenericDAO.deleteByAnd(GenericDAO.java:1251)
at org.ofbiz.core.entity.GenericHelperDAO.removeByAnd(GenericHelperDAO.java:236)
at org.ofbiz.core.entity.GenericDelegator.removeByAnd(GenericDelegator.java:1334)
at org.ofbiz.core.entity.GenericDelegator.removeByAnd(GenericDelegator.java:1313)
at com.atlassian.jira.ofbiz.DefaultOfBizDelegator.removeByAnd(DefaultOfBizDelegator.java:236)
Caused by: org.ofbiz.core.entity.GenericDataSourceException: SQL Exception while executing the following:DELETE FROM component (Table 'jiradb.component' doesn't exist)
at org.ofbiz.core.entity.jdbc.SQLProcessor.executeUpdate(SQLProcessor.java:570)
at org.ofbiz.core.entity.GenericDAO.deleteByAnd(GenericDAO.java:1281)
at org.ofbiz.core.entity.GenericDAO.deleteByAnd(GenericDAO.java:1248)
... 19 more
Caused by: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Table 'jiradb.component' doesn't exist
... 2 filtered
at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
at com.mysql.jdbc.Util.handleNewInstance(Util.java:425)
at com.mysql.jdbc.Util.getInstance(Util.java:408)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:944)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3978)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3914)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:2530)
at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2683)
at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2495)
at com.mysql.jdbc.PreparedStatement.executeInternal(PreparedStatement.java:1903)
at com.mysql.jdbc.PreparedStatement.executeUpdateInternal(PreparedStatement.java:2124)
at com.mysql.jdbc.PreparedStatement.executeUpdateInternal(PreparedStatement.java:2058)
at com.mysql.jdbc.PreparedStatement.executeLargeUpdate(PreparedStatement.java:5158)
at com.mysql.jdbc.PreparedStatement.executeUpdate(PreparedStatement.java:2043)
at org.apache.commons.dbcp2.DelegatingPreparedStatement.executeUpdate(DelegatingPreparedStatement.java:98)
at com.atlassian.jira.ofbiz.sql.PreparedStatementWrapper.executeUpdate(PreparedStatementWrapper.java:47)
at org.ofbiz.core.entity.jdbc.SQLProcessor.executeUpdate(SQLProcessor.java:562)
... 21 more
2019-06-07 10:49:07,886 JiraImportTaskExecutionThread-1 WARN anonymous 649x21x1 1iwhrv5 0:0:0:0:0:0:0:1 /secure/SetupImport.jspa [c.a.j.p.d.dao.impl.CachingOrganizationDaoImpl] onImportCompleted - clearing cache !!
2019-06-07 10:49:07,890 JiraImportTaskExecutionThread-1 INFO anonymous 649x21x1 1iwhrv5 0:0:0:0:0:0:0:1 /secure/SetupImport.jspa [c.a.j.bc.dataimport.DefaultDataImportService] Importing data is 100% complete...
2019-06-07 10:49:07,890 JiraImportTaskExecutionThread-1 INFO anonymous 649x21x1 1iwhrv5 0:0:0:0:0:0:0:1 /secure/SetupImport.jspa [c.a.j.bc.dataimport.DefaultDataImportService] JIRA Data Import has finished.
June 6, 2019
Hi Dave, its already added lower_case_table_names = 1 in my.cnf file
also kindly find screenshot of MySQL Db
June 6, 2019
Hi @Abhijit Dongre
I see you use utf8mb4.
This should be utf8
Regards
Dave
Hi Dave, when I earlier created database using utf8, then it was throwing error as 'your database doesn't support utf8mb4, so I created new one.
Please guide, shall I execute below command
ALTER SCHEMA `jiradb` DEFAULT CHARACTER SET utf8 DEFAULT COLLATE utf8mb4_bin;
