2018-09-17 15:23:28,986 JIRA-Bootstrap ERROR [c.a.jira.health.HealthChecks]
JIRA couldn't connect to your database
2018-09-17 15:23:28,987 JIRA-Bootstrap ERROR [c.a.jira.health.HealthChecks]
JIRA failed to establish a connection to your database.
This could be because:
- Your database isn't running
- The configuration of your dbconfig.xml file is incorrect (user, passwo
rd, or database URL etc.)
- There is a network issue between JIRA and your database (e.g. firewall
, database doesn't allow remote access etc.)
There are several other solutions you can try, review our documentation and
see what works for you.
Points to note:
1. I have turned off Firewall.
2. Database is running on port 3306.
3. dbconfig.xml is given below
<?xml version="1.0" encoding="UTF-8"?>
<jira-database-config>
<name>defaultDS</name>
<delegator-name>default</delegator-name>
<database-type>mysql</database-type>
<schema-name>PUBLIC</schema-name>
<jdbc-datasource>
<url>jdbc:mysql://127.0.0.1:3306/jiradb?useUnicode=true&characterEncoding=UTF8&sessionVariables=default_storage_engine=InnoDB</url>
<driver-class>com.mysql.cj.jdbc.Driver</driver-class>
<username>root</username>
<password></password>
<pool-min-size>20</pool-min-size>
<pool-max-size>20</pool-max-size>
<pool-max-wait>30000</pool-max-wait>
<min-evictable-idle-time-millis>4000</min-evictable-idle-time-millis>
<time-between-eviction-runs-millis>5000</time-between-eviction-runs-millis>
<pool-max-idle>20</pool-max-idle>
<pool-remove-abandoned>true</pool-remove-abandoned>
<pool-remove-abandoned-timeout>300</pool-remove-abandoned-timeout>
</jdbc-datasource>
</jira-database-config>
Thanks friends, I have resolved this.
I ran config.bat and saved its dbconfig.xml.
Then I downloaded the mysql-connector-java-5.1.46, which worked for me.
<jdbc-datasource>
<url>jdbc:mysql://address=(protocol=tcp)(host=localhost)(port=3306)/jiradb?useUnicode=true&characterEncoding=UTF8&sessionVariables=default_storage_engine=InnoDB</url>
<driver-class>com.mysql.jdbc.Driver</driver-class>
<validation-query>select 1</validation-query>
<min-evictable-idle-time-millis>60000</min-evictable-idle-time-millis>
<time-between-eviction-runs-millis>300000</time-between-eviction-runs-millis>
<pool-test-on-borrow>false</pool-test-on-borrow>
<pool-test-while-idle>true</pool-test-while-idle>
<validation-query-timeout>3</validation-query-timeout>
</jdbc-datasource>
@DEEPAK BHATIA, Are you able to ping your Database server as like below:
ping 123.456.789.012 (i.e your database URL)
For reference you can go through the article for usual database connection problems.
