Not able to create Epic using Jira Rest API
Colombia.pos .
September 27, 2018
I'm Using Jira rest API version 3, to create an issue type Epic by Below Post Request.
https://example.jira.com/rest/api/3/issue
but getting below error:
"errorMessages": [],
"errors": {
"customfield_11301": "Field 'customfield_11301' cannot be set. It is not on the appropriate screen, or unknown."
On my project, customfield_11301 maps to Epic Name which is already attached to the appropriate screen.
I'm Currently using administration access for API authorization. I have also provided all the high-level permission on the permission scheme attached to my project.
Please provide a solution to solve this issue.
Matthias Gaiser [K15t]
Hi @Colombia.pos .,
Just to make sure you did check the correct screen. I usually do it like this:
  • Go to the project settings
  • Navigate to screens
  • Expand the section which contains the Epic
  • Click on the create screen for Epic
  • Check if the field is on this screen
It happened often enough to myself that I checked the wrong screen.
Does your problem still exist? If yes, please also try if it happens with the API version 2 since v3 is still in beta.
Matthias
