Not able to create filter to display issues in an Epic
Gosia Gudan November 3, 2021
Hello, I have a problem with the filters in the issue navigator.
I use Epics in my project and I want to be able to create a filter for all the issues in a single Epic.
When I select a filter for Epic Name or Epic Link, the list is empty (and I have 39 epics in that project), please see screenshot:
When I use JQL to create a filter it's not giving me any results (and I have 23 child issues in the selected epic):Screenshot 2021-11-03 at 14.42.45.png
We have many projects in the company, and on other projects, I have no problems with creating such filers.
I'll appreciate it if someone can help me to understand what is wrong here.
Thanks!
4 votes
Trudy Claspill
Are you using a Team Managed project or a Company Managed project? It will say at the bottom of the navigation pane when you are viewing the project's board.
If you are using a Team Managed project, the field you need to use in your search, set to the Epic Issue Key, is Parent.
Company Managed projects record the parent Epic Issue Key in the Epic Link field for a child issue. Team Managed projects record the parent Epic Issue Key in the Parent field for a child issue.
@Trudy Claspill
Bingo, it worked! I use team-managed project.
Thank you for your help! :)
Mayur Jadhav
Hi @Gosia Gudan
Welcome to the Atlassian Community!!!!
Yes Whatever you have written JQL which is correct you missed to use " " at your epic issuekey number. Once you add it will show your linked issues.
I have attached a screenshot for your reference.
Please let me know if its helpful!!!
Mayur
Hey @Mayur Jadhav
Thank you for the reply.
I tried both with "and without, and it didn't work. It looks more like the stories don;t really have a connection with the Epic.
Please see screenshots:
1. Epic linked in the filter has 23 child issues, nothing is displayed:
2. When filter for all the stories in my project, epics are not displaying in the Epic Name and Epic Link columns
Maybe this could be the reason:
I'll appreciate any advice here.
I didn't find any information about this in the project settings.
Mayur Jadhav
Hi @Gosia Gudan
I guess all relationship between epic and story is missed, you need to manually create relationship again.
Mayur Jadhav
Can you please tell me the what kind of project you are using either Team Managed or Company Managed ?
@Mayur Jadhav it's a Team Managed project
@Mayur Jadhav thanks for your help, problem solved in the answer above :)
Like Mayur Jadhav likes this
