Not able to edit multiple links of issue in an issue
Ankur Mehrotra
Hi Team
I have added multiple link of issues to an issue by calling a post function on the click of create button in a workflow.
But since there is no edit option available in the workflow,I am unable to add multiple links to an issue.
Please advise further.
Thanks in advance
Thanks Ankur
Nic Brough -Adaptavist-
June 12, 2014
I'm not sure what the question is here - you've talked about a post-function to add links but I don't know what that has to do with the edit in the workflow (or even what "edit in the workflow" means - do you mean the transition screen where you can update fields during a transition?)
Ankur Mehrotra
Yes I am talking about the update fields during transition
June 12, 2014
Ok, so what's the post-function relevance, and what are you actually trying to do?
Ankur Mehrotra
Problem - I want to add multiple link - issues to an issue while I am editing an issue.
When I am creating an issue , I am able to add multiple links through a post function which is called in the workflow of creation.
The same thing I want to achieve is when I am doing edit to an issue.
Since edit is not part of any workflow , hence I am unable to do the same.
Please advise.
June 12, 2014
Ah, I see.
No. The Edit function does not have post-functions.
Your options are to move Edit into the workflow (so don't allow your users to edit directly, just move through the flow) or do your link additions as a listener instead of a post-function. A listener can pick up "issue updated" events thrown by the edit function and act on them.
Ankur Mehrotra
Thanks a lot Nic
