I am not able to find around 1850 issues from one of our project "Archive ET". Issues between AE-20874 and
AE-22724 are missing. Would like to know where my issues are and why it is not showing up in my project?
Hey Tarik,
From your description "Archive ET" being the project name it sounds like you may have moved these issues from another project with a bulk move, for archiving purposes, is this correct?
If so I am working on testing out an BUG related to bulk operations, where Issue Security locks all users out of some or all issues in a project, and cannot be found in the UI. I have a Knowledge base article here: https://confluence.atlassian.com/display/JIRAKB/Issue+Security+Levels+Locks+Issues+From+All+Users
Please check this out and let us know if this is your case as well.
They could also have been deleted or moved, or your index damaged.
Problem is there are around 22724 issue under AE-Projects. But now I am not able to find issues from AE-20875 to AE-22724. What to know what happen to those issue as there are no delete right to other users other then Admin and no one delete those issue.
Could you work through the first three points please? What happens when you try http://yourjira/browse/AE-21000 ? That will answer the first two points. Then check what the security scheme is on the project? Then we can talk about deletion. But there's no point in talking about delete until you've checked the other three possibilities.
Hi Tarik,
Your problem description is not clear enough to determine what the problem is.
However, I suspect there is an issue security scheme active on the project
(or there was and it was not removed correctly)
