Not able to get bonfire extension for IE
Anders Ingestedt August 26, 2012
The bonfire extension does not install in Internet Explorer. Chrome and Firefox work fine. The installation completes successfully but the extension never shows up. I have checked that the Enable third-party browser extension is checked.
Harry Chan
August 26, 2012
Hi, can you check if Active Scripting is enabled? More information can be found in https://confluence.atlassian.com/display/BONFIREKB/Bonfire+doesn't+work+in+IE+due+to+Security+Settings
Anders Ingestedt October 10, 2012
The problem according to atlassian support is that the 64-but version of IE is not supported. The improvement you can vote on is here: https://jira.atlassian.com/browse/BON-85.
