tar -xvf /home/srjiv/Downloads/mysql-connector-java-5.1.31.tar.gz
cd mysql-connector-java-5.1.31
cp mysql-connector-java-5.1.31-bin.jar /opt/atlassian/jira/lib/
Connection refused usually means you've not given Jira the right connection details, and/or you haven't granted the Jira user the right to use the database you've created for it.
Hi Srijiv, the message "Communications link failure" makes me think that there may be an issue with the access to the database. Are JIRA and MySQL installed on the same server or different servers? You may test the connection with the Telnet command (telnet mysql_server_name 3306)
Additionally, you may check if you're able to connect to this database using another software as dbvisualizer to check whether the connection is working.
I hope it helps.
Cheers
Hi Nic and Tiago , appreciate your quick response, thankyou very much.
Nic , to answer your question, I am absolutely new to mysql. I tried to give user -jiradbuser complete permission for database mysql, but it is throwing an error with incorrect syntax.
Tiago, yes Jira and mysql are running on the same server. When I try to telnet to the mysql server, it is not able to connect
C:\Users\Srijiv>telnet 10.214.10.51 3306
Connecting To 10.214.10.51...Could not open connection to the host, on port 3306
: Connect failed
Definitely the database settings then.
Telnet to the database server on port 3306 failing really does mean it's not listening at all, so it's no surprise that you can't get Jira to connect.
The usual trick for debugging mysql is to use the mysql client to attempt to debug it, if you have that installed as well. However, in this case, mysql simply isn't listening yet, so it's more fundamental than the connection settings.
How are you running mysql server on the box? Are you sure it's running and are you sure it's configured for port 3306?
(As an aside, connecting to 8080 is actually proving that Jira is running there, which I think we already know, it's nothing to do with mysql yet)
Hi Srijiv, you can use the follow command to grant the database access:
GRANT SELECT,INSERT,UPDATE,DELETE,CREATE,DROP,ALTER,INDEX on <JIRADB>.* TO '<USERNAME>'@'<JIRA_SERVER_HOSTNAME>' IDENTIFIED BY '<PASSWORD>'; flush privileges;
As for the telnet command, it may be that Windows firewall is blocking the connection. You may want to disable it temporarily to check whether it's the case.
Cheers
No, that implies that it's not listening on 3306, despite your config file.
I'm not sure how to debug that - I'd start with a look in /var/log/mysql (and check the settings file to see if the logs are elsewhere)
Hi Nic and Tiago , I think so that the mysql is running and with the settings I posted.
[client]
password = cisco.123
port = 3306
socket = /var/run/mysqld/mysqld.sock
Gauss ~ # /etc/init.d/mysql restart
* Stopping mysql ... [ ok ]
* Starting mysql ... [ ok ]
However when I do :-
Gauss ~ # netstat -a | grep 3306
Gauss ~ #
This is what I see under /var/log/mysqld.conf
140717 8:25:49 InnoDB: Started; log sequence number 0 44233
140717 8:25:49 [Note] Event Scheduler: Loaded 0 events
140717 8:25:49 [Note] /usr/sbin/mysqld: ready for connections.
Version: '5.1.70-log' socket: '/var/run/mysqld/mysqld.sock' port: 3306 Gentoo Linux mysql-5.1.70
140717 9:14:29 [Note] /usr/sbin/mysqld: Normal shutdown
140717 9:14:29 [Note] Event Scheduler: Purging the queue. 0 events
140717 9:14:29 InnoDB: Starting shutdown...
140717 9:14:32 InnoDB: Shutdown completed; log sequence number 0 44233
140717 9:14:32 [Note] /usr/sbin/mysqld: Shutdown complete
140717 9:14:32 [Warning] No argument was provided to --log-bin, and --log-bin-index was not used; so replication may break when this MySQL server acts as a master and has his hostname changed!! Please use '--log-bin=mysqld-bin' to avoid this problem.
140717 9:14:32 InnoDB: Initializing buffer pool, size = 16.0M
140717 9:14:32 InnoDB: Completed initialization of buffer pool
140717 9:14:32 InnoDB: Started; log sequence number 0 44233
140717 9:14:32 [Note] Event Scheduler: Loaded 0 events
140717 9:14:32 [Note] /usr/sbin/mysqld: ready for connections.
I now get a screen which asks me to choose wheather I would like to go with Jira or Jira with Agile or Jira with Service Support. Does this means that the mysql is now integrated with Jira ? How could I check that ? It is no longer asking me to enter the mysql information like the database name or the database user . Is this normal ?
That means it's connected now. I can't see what you've changed to make it work from what you've posted.
I dint changed any thing. Just stopped and restarted the services for Jira, and when I tried logging into the server, it took me directly to the bove options. I dout that mysql is integarated into Jira.
Something that was not working started working. You must have changed something at some point.
Jira will not function without a database behind it. You have either selected a different database type (the hsql one is built in and requires no configuration, but shouldn't be used for anything other than dev/test) or you've made MySQL work. You can check on the system-information page.
