×Hi
I have installed Jira 7.6.1 and link to mySQL database after setting Jira using in-built database.
After linking to mysql, when I start Jira in browser, error 503 received.
Need your support to start configuring my project
In the end we found that $JIRAHOME/dbconfig.xml file had a leftover configuration line from when it was using the H2 database: <schema-name>PUBLIC</schema-name>
This should not exist for a MySQL database as such, so by removing this and saving that file, Biswajit was able to resolve this issue.
You can also use the Jira Config Tool in order to make sure that your dbconfig.xml is properly setup for your database type. This might be one way to avoid this kind or problem too.
This fixed my issue, thanks! The Jira Config Tool (config.sh) is the one that generated the dbconfig.xml file for me so not quite sure why it was incorrectly adding in that line.
Interesting, what version of Jira are you using? Curious if maybe there are clear steps we can document to reproduce this. If so, I can write up a bug report that could help others avoid this problem in the future and get this fixed long term (if it hasn't been fixed already).
Below are some lines from the end of the filee
2017-12-21 20:51:04,074 JIRA-Bootstrap ERROR [c.a.jira.health.HealthChecks] We couldn't start JIRA
2017-12-21 20:51:04,074 JIRA-Bootstrap ERROR [c.a.jira.health.HealthChecks] An error occurred while trying to start JIRA. We can't give you any more detail right now, we suggest checking the logs for more detail and contacting our support team.
See our documentation for more information on contacting our support team and creating a support zip.
2017-12-21 20:51:04,074 JIRA-Bootstrap INFO [c.a.jira.startup.DatabaseLauncher] Database transactions enabled: true
2017-12-21 20:51:04,074 JIRA-Bootstrap INFO [c.a.jira.startup.DatabaseLauncher] Using JIRA's default for database transaction isolation level: 2
2017-12-21 20:51:04,082 JIRA-Bootstrap WARN [c.a.jira.startup.DatabaseLauncher] JRADEV-23357: unable to select from the 'MovedIssueKey' entity.
2017-12-21 20:51:04,082 JIRA-Bootstrap ERROR [c.a.jira.startup.LauncherContextListener] Unable to start JIRA.
com.atlassian.jira.exception.DataAccessException: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Table 'jiradb.MOVED_ISSUE_KEY' doesn't exist
at com.atlassian.jira.startup.DatabaseLauncher.cleanupDatabaseTableName(DatabaseLauncher.java:261)
at com.atlassian.jira.startup.DatabaseLauncher.cleanupDatabaseTableNames(DatabaseLauncher.java:217)
at com.atlassian.jira.startup.DatabaseLauncher.start(DatabaseLauncher.java:79)
at com.atlassian.jira.startup.DefaultJiraLauncher.lambda$postDbLaunch$2(DefaultJiraLauncher.java:150)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrEnqueue(DatabaseConfigurationManagerImpl.java:304)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrWhenDatabaseActivated(DatabaseConfigurationManagerImpl.java:199)
at com.atlassian.jira.startup.DefaultJiraLauncher.postDbLaunch(DefaultJiraLauncher.java:146)
at com.atlassian.jira.startup.DefaultJiraLauncher.lambda$start$0(DefaultJiraLauncher.java:105)
at com.atlassian.jira.util.devspeed.JiraDevSpeedTimer.run(JiraDevSpeedTimer.java:31)
at com.atlassian.jira.startup.DefaultJiraLauncher.start(DefaultJiraLauncher.java:103)
at com.atlassian.jira.startup.LauncherContextListener.initSlowStuff(LauncherContextListener.java:160)
at java.lang.Thread.run(Thread.java:745)
Caused by: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Table 'jiradb.MOVED_ISSUE_KEY' doesn't exist
at sun.reflect.GeneratedConstructorAccessor12.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
at com.mysql.jdbc.Util.handleNewInstance(Util.java:425)
at com.mysql.jdbc.Util.getInstance(Util.java:408)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3973)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3909)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:2527)
at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2680)
at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2480)
at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2438)
at com.mysql.jdbc.StatementImpl.executeQuery(StatementImpl.java:1381)
at org.apache.commons.dbcp2.DelegatingStatement.executeQuery(DelegatingStatement.java:207)
at com.atlassian.jira.startup.DatabaseLauncher.cleanupDatabaseTableName(DatabaseLauncher.java:245)
... 11 more
2017-12-21 20:51:04,085 JIRA-Bootstrap INFO [c.a.jira.startup.LauncherContextListener] Memory Usage:
Heap memory : Used: 115 MiB. Committed: 479 MiB. Max: 736 MiB
Non-heap memory : Used: 61 MiB. Committed: 63 MiB. Max: 1264 MiB
TOTAL : Used: 176 MiB. Committed: 542 MiB. Max: 2000 MiB
2017-12-21 20:51:12,935 http-nio-8080-exec-1 ERROR anonymous 1251x1x1 - 10.3.2.143 / [c.atlassian.instrumentation.Instrument] Unable to snapshot thread local operations (implementation of OpTimerFactory is not a ThreadLocalOpTimerFactory): null
2017-12-21 20:51:12,989 http-nio-8080-exec-2 WARN anonymous 1251x2x1 - 10.3.2.143 /secure/errors.jsp [c.a.jira.security.JiraSecurityFilter] Rejecting security-sensitive request that bypassed Johnson filter: /secure/errors.jsp
2017-12-21 20:51:22,523 http-nio-8080-exec-4 WARN anonymous 1251x4x1 - 10.3.2.143 /secure/errors.jsp [c.a.jira.security.JiraSecurityFilter] Rejecting security-sensitive request that bypassed Johnson filter: /secure/errors.jsp
2017-12-21 20:55:33,477 http-nio-8080-exec-6 WARN anonymous 1255x6x1 - 10.3.2.143 /secure/errors.jsp [c.a.jira.security.JiraSecurityFilter] Rejecting security-sensitive request that bypassed Johnson filter: /secure/errors.jsp
This error logs seems to indicate that the database is not yet setup correctly or the user Jira is connecting to that database with does not have all the needed permissions. I would recommend trying to follow this guide very closely: Connecting Jira to MySQL database.
It could be that the user in MySQL does not have permissions, or it could be that some other detail of the database configuration, such as the isolation level is incorrect for Jira to be able to use this database.
Try to recreate this database per that guide. If you're still seeing problems on startup, try looking into the $JIRAINSTALL/logs/catalina.out log file as well. This log file can sometimes have some other information that might not make its way into the atlassian-jira.log file in the home directory.
Hi Andrew
I am getting error like Table 'jiradb.MOVED_ISSUE_KEY' doesn't exist.
When i tried to check the tables in my jiradb, it shows empty set (show tables;).
I have rechecked for creating the database and driver, all looks good to me.
Is it expected that, some default tables will be created while setting the mysql and creating database???
Thanks a lot in advance for your guidance.
When you created the database, it should be largely empty. However once you connect this to Jira, and Jira starts up with an empty database, there are certain table that are expected to be created by the setup wizard and Jira itself.
If the database is setup correctly per that guide, then the other concern is to learn what values currently exist in the $JIRAHOME/dbconfig.xml file. It could be if this field has an unexpected value in it, Jira won't be able to correctly use this database as expected. Please note this file is expected to contain your username/password for the database, you don't need to include those here to this forum, but the rest of that file I would like to see what content you have there in order to understand if maybe there is something in that file left over from when using the H2 database.
Hi Andrew, yes you are absolutely correct.
I got it resolved by removing <schema-name>PUBLIC</schema-name> line from my dbconfig.xml. I hope for MySQL DB, this line is not required.
Thanks you very much for the support
Cool, Thanks for letting us know the solution, I will add a short summary answer to this thread to clarify the answer here should other users have this same problem.
What does the error in the application log say is the problem?
Hi
Please find the details of what I have done
1. Install Jira 7.6.1 and MySQL 5.7.20 on my server
2. Did the initial jira set up using in-built databse
3. Did the configuration for my database in MySQL
4. Did the steps to connect Jira to my database
5. Test my database connection, below is output
Test Connection ([Y]/N)? > Y
Attempting to connect to localhost:3306/jiradb
Thu Dec 21 21:07:26 IST 2017 WARN: Establishing SSL connection without server's identity verification is not recommended. According to MySQL 5.5.45+, 5.6.26+ and 5.7.6+ requirements SSL connection must be established by default if explicit option isn't set. For compliance with existing applications not using SSL the verifyServerCertificate property is set to 'false'. You need either to explicitly disable SSL by setting useSSL=false, or set useSSL=true and provide truststore for server certificate verification.
Connection successful!
6. Tried to open Jira using the HTTP request, get the below error:
jira01.sasken.com is currently unable to handle this request.
HTTP ERROR 503"
the URL changes to "http://jira01.sasken.com:8080/secure/errors.jsp"
In log, many times the jdbc connection issue error displayed.
Any pointer to the solution, please help
Thanks you in advance
Hi
Thanks for your direction.
Copying the atlassian-jira.log for your reference and guidance.
2017-12-21 19:09:56,044 http-nio-8080-exec-1 ERROR anonymous 1149x1x1 - 10.3.2.143 /secure/errors.jsp [c.atlassian.instrumentation.Instrument] Unable to snapshot thread local operations (implementation of OpTimerFactory is not a ThreadLocalOpTimerFactory): null
2017-12-21 19:09:56,067 http-nio-8080-exec-1 WARN anonymous 1149x1x1 - 10.3.2.143 /secure/errors.jsp [c.a.jira.security.JiraSecurityFilter] Rejecting security-sensitive request that bypassed Johnson filter: /secure/errors.jsp
2017-12-21 19:09:56,873 http-nio-8080-exec-2 WARN anonymous 1149x2x1 - 10.3.2.143 /secure/errors.jsp [c.a.jira.security.JiraSecurityFilter] Rejecting security-sensitive request that bypassed Johnson filter: /secure/errors.jsp
2017-12-21 19:09:57,620 http-nio-8080-exec-3 WARN anonymous 1149x3x1 - 10.3.2.143 /secure/errors.jsp [c.a.jira.security.JiraSecurityFilter] Rejecting security-sensitive request that bypassed Johnson filter: /secure/errors.jsp
2017-12-21 19:09:58,081 http-nio-8080-exec-4 WARN anonymous 1149x4x1 - 10.3.2.143 /secure/errors.jsp [c.a.jira.security.JiraSecurityFilter] Rejecting security-sensitive request that bypassed Johnson filter: /secure/errors.jsp
2017-12-21 19:09:58,397 http-nio-8080-exec-5 WARN anonymous 1149x5x1 - 10.3.2.143 /secure/errors.jsp [c.a.jira.security.JiraSecurityFilter] Rejecting security-sensitive request that bypassed Johnson filter: /secure/errors.jsp
2017-12-21 19:09:58,576 http-nio-8080-exec-6 WARN anonymous 1149x6x1 - 10.3.2.143 /secure/errors.jsp [c.a.jira.security.JiraSecurityFilter] Rejecting security-sensitive request that bypassed Johnson filter: /secure/errors.jsp
2017-12-21 19:14:47,616 http-nio-8080-exec-7 WARN anonymous 1154x8x1 - 127.0.0.1 /secure/errors.jsp [c.a.jira.security.JiraSecurityFilter] Rejecting security-sensitive request that bypassed Johnson filter: /secure/errors.jsp
2017-12-21 19:53:51,032 http-nio-8080-exec-8 WARN anonymous 1193x9x1 - 10.3.2.143 /secure/errors.jsp [c.a.jira.security.JiraSecurityFilter] Rejecting security-sensitive request that bypassed Johnson filter: /secure/errors.jsp
2017-12-21 19:53:53,749 http-nio-8080-exec-9 WARN anonymous 1193x10x1 - 10.3.2.143 /secure/errors.jsp [c.a.jira.security.JiraSecurityFilter] Rejecting security-sensitive request that bypassed Johnson filter: /secure/errors.jsp
Usually means Jira has not finished starting up, or it's failed for some reason.
What does the application log say is the problem?
Defaults to <jira home>/logs/atlassian-jira.log , although you might also need to look at <jira install>/log/catalina.out
