Not able to retrieve JIRA assignee in filtersubscription.vm file
Tukaram Bhukya [L&T INFOTECH] July 22, 2014
Please help me , i'm using jira 6.1.5 version
I try to retrieve issue assignee and reporter users in filtersubscription.vm file but its not retrieving
i'm using below commands to retrieve values
#set ($assign=$issue.getAssigneeUser().getDisplayName())
$assign
#set ($repot=$!issue.reporterUser.fullName)
$repot
Jobin Kuruvilla [Adaptavist]
July 22, 2014
try
#set ($assign=$issue.getAssignee().getDisplayName())
Thanks for reply.
It didn't work , please any alternate solution
please find attached file
Please help me in this here is end user sent attached sample email template.
They are expecting email as mentioned in attached template .
July 22, 2014
I don't see any attached file. Not sure why the above code doesn't work because it should work as per the APIs. Did you restart to make sure the updated template is loaded?
i restarted but it didn't work
