Not able to start sprint using python-jira API
Ravi November 11, 2016
I am trying to start a sprint using python-JIRA API:
jira.update_sprint(13, state='ACTIVE')
I seeing following error:
esponse text = {"message":"Unrecognized field \"state\" (Class com.atlassian.greenhopper.web.rapid.sprint.model.UpdateSprintRequest), not marked as ignorable\n at [Source: org.apache.catalina.connector.CoyoteInputStream@15ae364; line: 1, column: 12] (through reference chain: com.atlassian.greenhopper.web.rapid.sprint.model.UpdateSprintRequest[\"state\"])","status-code":500,"stack-trace":"org.codehaus.jackson.map.exc.UnrecognizedPropertyException: Unrecognized field \"state\" (Class com.atlassian.greenhopper.web.rapid.sprint.model.UpdateSprintRequest), not marked as ignorable\n at [Source: org.apache.catalina.connector.CoyoteInputStream@15ae364; line: 1, column: 12] (through reference chain: com.atlassian.greenhopper.web.rapid.sprint.model.UpdateSprintRequest[\"state\"])\n\tat org.codehaus.jackson.map.exc.UnrecognizedPropertyException.from(UnrecognizedPropertyException.java:53)\n\tat org.codehaus.jackson.map.deser.StdDeserializationContext.unknownFieldException(StdDeserializationContext.java:267)\n\tat org.codehaus.jackson.map.deser.std.StdDeserializer.reportUnknownProperty(StdDeserializer.java:673)\n\tat org.codehaus.jackson.map.deser.std.StdDeserializer.handleUnknownProperty(StdDeserializer.java:659)\n\tat org.co
Please someone help with this.
Nic Brough -Adaptavist-
November 12, 2016
It looks like the python-JIRA API is sending data that JIRA does not need or expect.
Have you tried making the call over the REST API (this is what the python wrapper calls, so it's worth checking if that gives a similar error)?
Ravi November 12, 2016
Can you point me such link, how i can call those APIs from python.
November 13, 2016
See https://docs.atlassian.com/jira-software/REST/latest/#agile/1.0/sprint and have a look at the "update" call which starts sprints.
