We are using Multi Level Cascading Plug-in for JIRA softwrae. However, at present my JIRA is not able to locate any .csv file for uploading in the custom fields by Multi Level Cascading.
It was working fine after implementation, problem started recently.
The System Log:
Technical details
Log's referral number: 76d75ce3-898c-4c45-9ec4-7df886014e02
Cause
Referer URL: https://tlsjira.ltdic.com/secure/admin/ImportOptionsFromCsv.jspa?customFieldId=10325&fieldConfigId=10525
java.lang.ArrayIndexOutOfBoundsException: 0
at com.sourcesense.jira.plugin.importer.util.OptionsNode.addElement(OptionsNode.java:30) [?:?]
at com.sourcesense.jira.plugin.importer.util.OptionsTree.addElement(OptionsTree.java:16) [?:?]
at com.sourcesense.jira.plugin.webwork.ImportOptionsFromCsvAction.doImportOptions(ImportOptionsFromCsvAction.java:125) [?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) [?:1.8.0_102]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) [?:1.8.0_102]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) [?:1.8.0_102]
at java.lang.reflect.Method.invoke(Method.java:498) [?:1.8.0_102]
at webwork.util.InjectionUtils$DefaultInjectionImpl.invoke(InjectionUtils.java:70) [webwork-1.4-atlassian-30.jar:?]
at webwork.util.InjectionUtils.invoke(InjectionUtils.java:56) [webwork-1.4-atlassian-30.jar:?]
at webwork.action.ActionSupport.invokeCommand(ActionSupport.java:438) [webwork-1.4-atlassian-30.jar:?]
at webwork.action.ActionSupport.execute(ActionSupport.java:157) [webwork-1.4-atlassian-30.jar:?]
at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:63) [jira-api-7.9.0.jar:?]
at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:39) [webwork-1.4-atlassian-30.jar:?]
at webwork.interceptor.NestedInterceptorChain.proceed(NestedInterceptorChain.java:31) [webwork-1.4-atlassian-30.jar:?]
at webwork.interceptor.ChainedInterceptor.intercept(ChainedInterceptor.java:16) [webwork-1.4-atlassian-30.jar:?]
at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:35) [webwork-1.4-atlassian-30.jar:?]
at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:225) [webwork-1.4-atlassian-30.jar:?]
at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:154) [webwork-1.4-atlassian-30.jar:?]
at com.atlassian.jira.web.dispatcher.JiraWebworkActionDispatcher.service(JiraWebworkActionDispatcher.java:138) [classes/:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729) [servlet-api.jar:?]
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:230) [catalina.jar:8.5.6]
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:165) [catalina.jar:8.5.6]
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) [tomcat-websocket.jar:8.5.6]
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:192) [catalina.jar:8.5.6]
at com.atlassian.jira.web.filters.JiraLastFilter.lambda$doFilter$0(JiraLastFilter.java:39) [classes/:?]
at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:74) [classes/:?]
at com.atlassian.jira.web.filters.JiraLastFilter.doFilter(JiraLastFilter.java:36) [classes/:?]
at
Hey Abhik,
If I'm not mistaken, CSV import only supports the JIRA built-in Cascading field. It doesn't support Multi Level Cascading Plug-in:
Did you happen to use the JIRA built-in Cascading field earlier?
Best,
Andy
Hey Andy,
Nope..I was not using the JIRA in-built cascading field earlier, I was using the same Multi Level Cascading Plugin. Only instance happened in between is that I had renewed my License Key for same.
